I'm looking for info on the actuator that has the built in preload adjuster for the clutch actuation shaft. I have seen them and wondered what advantage there was to running one. I was also wondering if there was a difference between model years, R32, R33, R34. I've read that there is an upgrade to the stock one in that it reacts faster and applies more force at lock up.
Thanks
Mike
As you know the R32 GTR has no preload and the R33 GTR has some, but the 32/33 gtr gearbox/transfer case etc are exactly the same, ie. I;ve got a R32 gtr box in my R33 atm and everything is the same,,, ditto with the hydraulics aside from failsafe valve and A-LSD solenoid, the pre-load you speak of is completely controlled by the ETS computer.
for example, I can adjust/control the pre-load through my Full Race ETS controller.
So I'm not sure what preload adjuster you have seen...?
I know exactly what your referring to as I actually do the modifications to the actuators.
The actuator is modified so you can adjust the preload on the actual wet clutch pack inside the transfer case instead if relying on the atessa system to maintain residual line pressure.
The r33 clutch pack is slightly different internally.
A modified actuator lets you increase the minimum load on the clutch packs and decrease the lag time as the atessa system solonoid opens. It won't make the system react faster to sensor inputs.
What do you usually require to do this modification, the whole car ?>
No it doesn't lock the clutch pack tighter. If you do that you'll end up winding the transfer case up and smashing it to bits. Once the clutches are engaged that's it.
The modification to the actuator holds an adjustable amount of preload onto the actual clutch packs that is usually "free play" which the atessa hydraulic unit needs to take up before the awd will engage.
No don't require the car at all to do the modification. Just the transfer case actuator, push rod and about half hour on the phone to explain the setup procedure so it doesn't result in a smashed transfer case.
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
