The Turrr sound is BAD.... well sounds bad, that was on stock boost.... maybe higher boost will have the desired sound your after.... ot maybe just a louder TRRRRRRRR sound.
I have the Blitz BOV and it makes 1 single realese noise PCHHHHT although you can tighten the spring (via screw) and it will make less noise and tighten it enough you get the TRRRRR sound. After being D fected (Blitz bov was unhooked due to manifold work) i decided ill leave the stock one going for a while.....
  • Replies 40
block up stock bov or tighten aftermarket venting BOV or run no bov, it helps if u hav a exposed pod as the air escapes thru it, also type of cooler pipes, shape, length etc. how is the flutter different to the dut dut dut (are youreferring to the vl noise?). i hear some turbo cars which actually hav the BOV PSSSHHHfirst and then the flutter directly after, not the flutter during back off in low revs and the psssht while on boost as people usually think, any idea how this is achived out of curiousity
well there is heaps o fideas here but the general feeelin im getting is that it can caome from a sequential bov like a hks ssqv and i right. But also it can come from taking the bov off....but that is not a good idea? if im right can ne1 recommend ne good BOVs for this sound?
If you lossen the springs on your BOV/BOV's then you can get them to bounce on TC.
The ch ch ch sound CAN come from the valve opening then bouncing off the releasing air pressure because the valve spring is wound right off.
People with SSQ don't need to do this to get this effect to some degree because they have two seperate valves that are different sizes and spring rates therefore open at different boost levels. So that is why under a full boost/load release you can hear a puuuuush...ch ch ch. Its the large valve opening followed by the smaller valve flapping after the bigger valve has closed again.
Its also depends whether its a push type or pull type valve. One is better than the other if you're chasing the noise... whatever...
You guys can work out which one is better..
I always thought that cha cha cha was some kind of latino dance move?????
Sebaz
your mate doesent know shit :D
external gates has exhaust gas flowing through it, not the compressed air from the turbo.
How true is your first remark..
and look at some of the other replies to this post.. people still believe that a bov is going to make that sound..
I don't know why I bother giving decent replies sometimes..
I say GTST .... let em do there own R'N'D. That way when they spend way too much $$$$ they might listen to the advice given to them....
This is a public forum, and everyone is a car mechanic ... I mean i invented the wheel, space, earth, stars.... oh hang on.... no i just created everything on the 8th day
don't lie.. we both know I invented the wheel.. not you..
I guess it's like when you're younger and your parents say, don't do this or this will happen or study hard and get your edumacation done so you have more opportunities in the future..
and kids always have to try those things that there parents told them not to do and then go .. oh yeah.. they were right..
oh well. I thought that when it comes to spending money, people might actually listen instead of wasting there money... but.. live and learn I guess... who was it above.. spent $600 on an ARC bov... $600 for a bov?? it is a damn piston, spring and casing... with an adjustment screw on top.. you could make on in metal work class in year 10 if you wanted to..
or you could just realise that you can use the stock one with no problem until way over 200rwkw..
bah!! in the end, people are just STUPID.
On that note..
I have an APEXI TWIN CHAMBER bov for sale..
as used in the fast and furious.. on that supra in the first movie.. it's fully sick and twice as good as any other bov due to it having twice the number of CHAMBERS..
AND, it's shiny, giving it the ability to make all sorts of noises.. AND, it has a different adjuster which you can turn to make it make different noises.. REALLY..
$250 - special offer for all you mechanics.
and if you really want to believe it, the secondary chambers piston flaps around and dances to make all sorts of wonderful noises..
i didnt pay $600 for it, it was in my half cut i bought for my r31 rb20det conversion, but they retail for around $600, hard to find though, i had to do some research to find out a bit more bout it cause i wasnt to familiar with arc stuff, but found a few places that sell em and they are expensive as hell, but i dont care i got it free :D i would only ever pay up to $200 for a bov
a plumb back bov will make hardly any noise...
it will simply be a slight whoosh noise.
if you buy an aftermarket plumback like say from GFB, it will make less noise than the stock skyline plumback bov.
Benefit = skylines have an air flow meter. this measures the amount of air being passed through it and tells the ECU to supply enough fuel for the mixture. when you change gears, the plumback bov dumps this air back in to the air inlet so it is still in the system. with an atmo venting bov, the air gets out of the system via the bov but the ecu still supplies the fuel for the air that was measured as it went past the air flow meter.
so this causes temporary over fueling or running rich.
due to this overfueling a couple of things can/do happen.
1.) backfire on gear change or when you back off the throttle to slow down.
2.) black puff of smoke from exhaust when you get back on the gas after changing gears.
3.) stalling when coming to a stop at lights or intersections.
4.) sometimes car feels sluggish due to rich mistures.
5.) spark plugs foul up quicker.
6.) extra black shit on your rear bumper from the rich fumes out of the exhaust.
with a plumback bov, none of the above issues arrise..
does that answer your question?
Thats wat i told him. he talks alot of shit and thinks he knows heaps about cars. not like you guys... you know wat you're talking about. i think i know who my real friends are now. :)
Has anyone ever told you that you should work in sales?
You crack me up Tolga....
so does ne1 reakon a GFB stealth FX would b a good choice of a BOV?
No.
at $500 odd retail, why waste your money.
the purpose of that bov is so that you have it on full plumback when on street and then atmo when on the track for the full sick effect.
HOWEVER, if you have it on your car and set to plumback on the street and the cop checks it over and sees this big ass bov with a trumpet hanging off the side, he will defect you even if it is not set to atmo or half half..
do you have a stock bov? YES
are you running more than 18psi? - probably not
then don't worry about it..
use that $500 to buy a set of whiteline anti-sway bars... at least they AID performance..
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
