Alright well yeah closed is Capalaba for E-flex, about 15 mins no big deal. So basically find an ECU that can let me tune it to that fuel, any suggestions?
So e85 is better than 100?
Edited by skyline32sup
Link
Vipec
Haltech
Adaptronic
Not in any specific order of preference, those are just the ones that come to mind.
I think i'll be looking into a haltech from what I've read but we'll see how i go. Thoughts on just getting the tune for E85? I'm sure i can russet up a spot for a jerry can if i run out as said above.
I have bought a turbo setup from a guy off SkylineAus and will be running a Garret 3076 .82 along with 880cc injectors, unknown size of Wastegate most likely 38mm and etc. I've been looking into getting a Greddy plenum as well and also can't decide on Poncams or not.
m
  • 1 month later...
I know its an old topic, but ive since gotten a 3076r, 6boost top mount manifold and tial 38mm wastegate, i plan to get the haltech ecu that has dual fuel systems think its about $2000 and run e85, so would ID1000 injectors be the way to go? is that to over the top for the 98?
I'd say the ID1000s would be about right for that setup, yes - its way more than you need for 98 but you won't suffer any compromises from them either... they will work absolutely fine, and will supply enough fuel to keep the fire going safely on E85 too :)
  • 2 months later...
Figured might aswell bump this, I'm looking at clutches and i'm still a bit vauge on what would be a decent clutch for 300kw for a driven car thoughout the week/track days any suggestions? so it will be be raped and treated nicely lol. Was thinking NPC twin plate but there pricey but then again most twins are aswell, thanks guys!
just tossing in my two cents - i got stock 25 with bolt ons running e85 and cracked 315kw - using haltech and 740cc injectors - if i where you get the haltech flex sensor and id1000cc injectors to cover it -
my clutch is slipping and npc has recommend his clutch 800 deliverd and will handle 450kw - and suit street - track and drift.
lot of ppl hve said the excedy is good but not as good on street driving - at this stage i will be going with npc, plus the guys on here recommend them - if i had 2 grand i woluld go the nismo clutch or what ever its called
I've already got my injector setup, running ffp with 850cc sards, was going to go E85 but not now. I'm running a Haltech Plug and Play.
Yeah I'll have to contact them i think about a clutch they seem to be decent for their price
NPC clutch will be the way to go. No need for twin plate at that level. Your crazy not going e85 man. Motor will be so much more reliable on e85. The sard injectors will be fine with e85 for 350kw atw's. Get the the same clutch reese69 described.
dont quote me on the clutch lol i havnt got mine yet - but the guys here have said npc or the nismo one which is a massive price difference
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
