I have just this week noticed that when my R33 GTS-T hits boost (only 10 psi) at around 3000rpm in 4th or 5th gear (under moderate to heavy throttle) that the revs initially rise quickly (without as much thrust!) and then dip slightly before continuing to boost OK...
Could this be the clutch slipping???
It feels a lot like it, but I've only ever blown clutches (admittedly in FWD cars) in lower gears and usually when revs are high!!!
Is it the torque that causes the clutch to slip??? It doesn't slip and dip in any lower gears!!!
Could it be a boost pressure issue??? I have a basic bleed valve installed. I can't think why this would cause this but I'm certainly no mechanic!!!
IDEAS??? I already did some searches and came up empty!!!
Ta!
iijj
https://www.sau.com.au/forums/topic/41766-clutch-in-4th-and-5th/
Ta!
iijj
I think u need a new clutch. Ur case is just like wat had happened to me before. Starts to slip only at high speed (4th n 5th gear).
Bummmmmmmer........
So, anyone know a decent place to price a clutch up here in Brissie???
I don't think I can afford a heavy duty clutch if they're $900 fitted!!!
How much do the standard clutches go for, including fitting, and ...
where should I get one???
I hardly ever drop the clutch in first, but I don't want it to blow again inside a couple of years either. Would I be better with a heavy duty item??? I'm only producing around 140KW atw...
Suggestions...
iijj
PS Hey, how long, if I nurse it somewhat, until it will give up altogether???
Iijj , quote for me was 350 for standard clutch and 550 for heavy duty. twin plates go up and up from there... i plan on making more than 200RWKW so a heavy duty is rated to the 300 rwkw range. If i wanted to make over 300 RWKW (read many $$$$$) I'd have gone for a twin or Triple plate item.
Personally get the best you can afford, cause there's nothing worse than making more power and the stock car parts can't handle it ;)..... I guess that's half the fun tho...:D
Loz
Thanks guys...
I'm waiting for a quote tomorrow. From what ur saying, I can count on b/w $600 and $900, depending on standard or heavy duty (and fitting)!?! Is that right???
If anyone else knows of a good shop in Bris North, speak up!!!
Thanks!!!
iijj
Try x-clutches they have been in Zoom magazine, they are in QLD and at underwood somewhere.
They have stock, heavy duty twin plates tripple plates, they are made here in Australia using stuff they don't tell anyone.
In Zoom they had a silvia or skyline doing around 400-500HP, and ask x-clutches about what to get and they said get our special coated stock plate and it'll handle it.
Anyway sus them out.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
