Reckon you could get 20% weight out of something that is already bare bones at 690kg? Always going to be limited by the chassis without doing massive work on it. Might as well be a sports sedan.
You'd never make minimum weight, but at least you aren't going to be restricted by that rule... The Japs get the TSCup version of the later, bigger, heavier B310 Sunny down to 670kg racing weight with FRP or carbon panels, bumpers and acrylic windows, And that starts life at something over 850kg. Still with no obvious fat on its bones. Pro allows you to cut out the boot floor and stuff as well.
As for the other point, what Pro Class car doesn't need massive work on its chassis? Except perhaps Cyber Evo... But guess what the secret to their speed was... aside from the aero and good driver that all the contenders had.
You can make good power from the original A12 or bigger A14-A15 with a turbo. They're a tough little unit, with plenty of aftermarket support. And one man can lift a complete engine! They're super compact too - get that 2" behind the firewall and V-mount the rad/intercooler as far back as possible.
You'd stay light with driveline and be prepared to break a few bits occassionally, rather than over-engineer it.
MX5 suspension could be the way to go - it works and its light. Do the NZ racecar trick of dropping the body down over the floorpan - sort of like a channelled rod, to get down to the 50mm permitted ride height.
As Roy says 400bhp and 700kg is not beyond the realms of possibility. And you'd have the smallest frontal area of any competitor other than a Lotus. And would be one of the cheapest Pro cars to build. So it wouldn't matter so much when they change all the rules again the followig year! lol
Edited by hrd-hr30
  • 1 month later...
Car is in the process of getting put back together. Hopefully be out next month to iron out all the bugs ;)
Have you done EC before on street radials? I remember getting down to 44s in my 33 with 350kw a couple of years ago... hope you can represent so its not a EVO fest!
I have, but no confirmation yet.
Also wanting to get into open, but dont know if they'll want a dirty 31 in their event :)
Who has expessed their interest and in what class? Anyone receive confirmation yet?.....hoping to represent in open!
:cheers:
:cheers:
I'm sitting this one out. Last year broke my 'modest' budget and this year I am focusing on other things. Still hoping to get out to a few club events and SAU nats later in the year. The to-do list is growing with the ideas I have for the car but they'll have to wait till next year.
I'll still be there but as a spectator this time. I'll come say hi Steve.
Nooooo Russ..... loved following your progress through the high and lows over the years ;)
Richo, make sure you kick my mates supra from gorilla industries :P
Haha!
What's the latest on big red?
Don't think it'll make an appearance this year. Adam has just begun some improved production racing in his gay Evo.
Already did last year :P
I'll be looking to be much faster than last year.
Got my confirmation yesterday :banana:
Shame that some of the season campaigners cant make it....
However, there seems to be some insane builds coming through in the motorsports section
3 x R32 GTRS that I've been getting excited about...
Ex BSM (John I think)
BC Auotmotive (Steve is it?)
Ex Willal (Dahn?)
Haven't met you lads in person but i look forward to it....
glad we can keep the EVO's honest
:cheers:
Steve
Ex Willal (Dahn?)
:cheers:
Steve
Awesome...more RB racers for the event!
Yes it's Danh and I am in as well.
Looking forward to catch up with you guys and good luck with the preparation :cheers:
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
