ah noooooooew.
We ran out of fuel!!! Ended up with a 1.04.9. Had a low 1.04 in it, but wasn't to be.
Huge challenge even to make the event. The old man and my brother put in a big effort.
In the weekends leading up to it we dropped a heap of weight, did heaps of maintenance to suspension bits, changed the diff (mine is broken, no time to fix), borrowing brake pads on Monday night (i was working in sydney tues-fri) and in the days before get a wheel alignment and new tyres (on Friday).
At a track I'd been too once before, with tyres I'd never run before (z222 285/35), with no ABS (borrowed diff was a non ABS unit) we ended up 4th in Club, so very close to 3rd.
Great result and congrats buddy especially with all the challenges . What's your car weighing in at now?
  • Like 1
ah noooooooew.
Great result well done.
"Alternative materials are permitted for the Front Bar, Bonnet, Side Skirts, Rear Bar and Boot provided they follow the same shape as the original part.
Alternative materials are permitted for front and rear flares.
Localised modifications of OEM fenders to allow fitment of the control tyre.
OEM fenders must be of original material however flare extensions are permitted to cover control tyre.
The top 1/3 of the tyre must not protrude outside the guard/flare when the wheels are facing forwards.
The remainder of the vehicle body must remain as original from the manufacturer. (no wide body kits)"
Bolt on flares
In Pro class they changed the following for chassis
  1. Rear retention of the original chassis:
  2. Original floor pan and frame rails must be retained from the firewall to the forward most point of the rear wheel arch. Allowance for removal material for fitment of fuel or fluid tanks and associated fittings is permitted
So you have to retain the floor plan and rails except you don't....... I heard that this one was coming as one of the top Australian Teams that was on the podium last year had actually had cut the entire middle of the car out for the fuel cell and oil tanks.
Short notice, is this affecting you guys at all? I need to re read them again... Especially with the new interpretations.
Alternative materials are permitted however all bodies must follow the same shape and retain the original look and style of the vehicle. Does following the same shape mean keeping the original side skirts? Keeping the original front bar?
Front and rear bars may be modified to incorporate aero design. Front bar may not extend further than 150mm forward and rear bar no further than 100mm rearward than the vehicles bodywork. Interesting
Yes those early Evo were very light.
I think they quoted the wrong minimum weight for the R32 GTR. Nissan produced a number of N1 car with a curb weight of around 1400kg. Let me try to dig out some more info
Ahhh Wikipedia it is http://en.wikipedia.org/wiki/Nissan_Skyline_GT-R:
The Skyline GT-R 'N1' model, introduced on July 19, 1991, was designed for home-market N1 racing with a total of 228 units produced. The most notable change was in the engine, which was upgraded to the R32-N1 specification. The car was also lightened by the removal of the ABS, air conditioning, sound system, rear wiper, trunk carpet, and the use of light-weight headlights. No color options were available and all 'N1' cars were delivered with a thin layer of Crystal White paint. The result was a 30 kg weight savings for a curb weight of 1,400 kg.
Edited by 9krpm
The Skyline GT-R 'N1' model, introduced on July 19, 1991, was designed for home-market [/size]N1 racing with a total of 228 units produced. The most notable change was in the engine, which was upgraded to the R32-N1 specification. The car was also lightened by the removal of the ABS, air conditioning, sound system, rear wiper, trunk carpet, and the use of light-weight headlights. No color options were available and all 'N1' cars were delivered with a thin layer of Crystal White paint. The result was a 30 kg weight savings for a curb weight of 1,400 kg.[/size]
Hey dan, this is correct but in the new rules state that the car must have been produced at least 500 units to comply, what do you think your car will weigh?
Bolt on flares
That's the one.
I'm extremely disappointed, but at the same understand why they have had to do it. If the vast majority of the field enter with cars that are not compliant to the rules, then the class either folds or the rules change to allow those cars to run.
It's stuffed me around to the tune of $3k in wheels (as I wanted to run 10.5 + 15 but wouldn't fit under the guards so bought wheels that could and in doing so decreased the chance of getting a 295 on there), if I was an Evo driver I'd probably have more of a say.
Basically to stay competitive I need to modify the guards now.
It's funny how the magical "500" number pop up. If it's good enough for the Japanese to accept the N1 for racing why isn't it good enough for time attack event :(
I suspect those Evo weight are not quite the mass produced version either. I suspect some bias here.
We will make it as low as possible and then add weight if we are under. Only WTAC requires minimum weight, the other events don't so I don't just build the car for that weight. It's not easy to get the GTR to below that any how but just in case. Not nice to see some unfairness of this magical 500 number. Does anyone know of any real reason for the "500"?
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • I guess one thing that might be wrong is the manifold pressure.  It is a constant -5.9 and never moves even under 100% throttle and load.  I would expect it to atleast go to 0 correct?  It's doing this with the OEM MAP as well as the ECU vacuum sensor. When trying to tune the base map under load the crosshairs only climb vertically with RPM, but always in the -5.9 column.
    • AHHHH gotchaa, I'll do that once I am home again. I tried doing the harness with the multimeter but it seems the car needed a jump, there was no power when it was in the "ON" position. Not sure if I should use car battery jump starter or if its because the stuff that has been disconnect the car just does send power.
