So my non turbo skyline has a idling problem. The car would just start reving itself out and holding. For example it would rev up to 1900-2000rpm and just stay there. I would rev the car and sometimes that brings it DOWN but most of the time it doesnt. Take it out of gear sometimes also brings it down.
Ive been told its a problem with the throttle position sensor. Ive tried moving the sensor a few times but i can never get the car to hold steady. Im wondering if buying a replacement would fix this problem. Thanks.
could be a number of things.... TPS is certainly one it will be a process of ilimination on these things. Could be AFM also? Sticky throttle?
start eliminating one by one and keep us informed so we can assist further :)
This leads me to think that the first thing to change would be the tps... but as said above it could be a process of elimination, I have a working tps, afm, aac valve and more so if you need anything shoot me a pm :)
Cheers
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 馃檪  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 馃槃 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
