Hello i am Mike, i am 19 years and coming from the Netherlands, and i am the proud owner of a 1991 red r32 gtst, i like gaming ofcourse :P, and watching way to much Anime, further do i like to be busy with cars ( especially JDM ones and the r32 as my all time favorite :) ) So you can guess that buying one was a dream come true for me.
But stil did i buy it with some work to be done to get it on the road again ( dutch rules once a year youre car has a test if everything is allright, I think youre country has that to right)
If you have questions ask them :P,
So here some pictures
This is how the car was 2 years ago nothing changed except that some moron owned it which f**ked the car more up then fixing it.
I really have to replace that ugly steeringwheel for a nice deepdish. ( and the Tenzo r seats for brides)
First i upgraded the old motoria exhaust for a new Japspeed 3 inch one ( old one was full of holes )
Fitted a Driftworks Hicas eliminator
side:
already fixed the front swaybar and front seats to ( seats where loose had to tapp new thread everywhere :( )
I am right now busy with fixing the right brake caliper with new seal etc ( 3 pistons are stuck )
i have already some parts at home waiting to mount to my car.
Cusco rear strutbar
Hks turbotimer type 0, with Harnass
Hks timing belt
Hks D1 limited oil filler cap
Nismo gearknob
Blitz radiator cap
Fmic
decat
this was it for now.
Edited by f5twister
https://www.sau.com.au/forums/topic/417745-newbie-from-the-netherlands/
My family is in Zwolle, Uncle and his wife and 3 cousins.
Visited them in 2009, was such a rad time.
My Opa lived in a place I can't spell... Leeuwarden sounds familiar... There were canals there if that helps! Ahahaha.
Can honestly say I didn't see one skyline over there..
btw: there arent many skylines driving in the winter here, thats because they throw salt on the road if it begins to freeze.
run exhaust straight onto ground, melt ice.
if salted, just hose it down underneath when you get home.
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
