I've got a problem with one of my headlights (RHS) and hopefully someone on here can point me in the right direction.
Just recently the light stopped working. I pulled the bulb out and gave everything around that area a few soft taps. Then it began working for about one day and now it has stopped again.
I've switched ballasts over and bulbs and all seem to be working fine. From what I can see it is the below pictured cable and box that seems to be the problem. This goes through the actual headlight connecting the ballast to the actual bulb.
Can anyone tell me exactly what this box does and where I can find a replacement? The headlights are aftermarket.
https://www.sau.com.au/forums/topic/417763-v35-headlight-problem-help/
That's a CAN BUS error cancelling unit.
CAN BUS is a communication system between multiple electrical sub-systems. It is commonly found on lots of European cars and ours too. In this instance, when you install aftermarket HID's it freaks out the CAN BUS into thinking you have a blown bulb and you get a 'light out' error. So they install these inline and it 'convinces the CANBUS that everything is fine - as it is.
You can buy replacements like this:
http://www.hidlighti..._De-Coders.html
But given it's probably a cheap kit to start with, you'd probably better off just buying a new kit for as much as you want to spend (i've run $40 kits in fog lights on another car before with no ill effect) and you'll have new components because odds are if this one fails, the other won't be far behind.
Edited by SMOKEYC34
Thankyou very much for the detailed reply mate. I was having a look through my spare parts and I came across a cable like the one pictured below (ignore the ballast).
I connected this and it made the bulb work but was giving off a buzzing sound. Would I be able to use this for now or do you think it would cause some damage not having the CAN BUS unit there?
http://www.oemxenonshop.com/OEM-Xenon-Headlights-Parts/Infiniti-G35-D2S-Ballast.jpg
Can you point me in the right direction for a complete kit to suit what I need? Just in case the other side goes..
if it works you will be sweet. HID's often make a noise, I wouldnt worry about it. The error canceller is just a big resistor at the end of the day.
For a replacement, if you want to do it on the cheap, just pick anything off eBay - i'm sure they're all same-factory-different-door anyway. Like i said, i've run $40 cheapies before with no ill effect. With the cheap ones though, you will find that they have longer startup times, the colours can be different between the two globes due to low quality control of salts in the globes, and they'll start to lose output and colour (get bluer, then purple) before probably crapping out in 18months time. But if that's cool with you, then I wouldn't advise against it. Just stick to 5000k or below. Anything higher you lose light output significantly, and with lower quality kits thats probably going to emphasise the loss.
If you want to spend a little more, bang for your buck I'd recommend the Morimoto Digital kit from theretrofitsoure.com - they're quality digital ballasts (nice and compact) and quality output globes. Go for a 4300k (OEM colour white/yellow) or a 5000k (white/blue tinge). They will give you excellent light output and last much longer.
Thanks again mate, if you're sure it won't blow the bulb or something like that I will just go ahead and use the older cable with the CAN BUS unit until I find a new one.
I know they never made this noise before which is why I was a bit worried about using it that's all.
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
