  • Replies 71
Forgive my ignorance but how is drink driving whilst doing 200 clicks cool?
in south africa things are different to here,
i doubt he was drunk tho, 6 was just a dramtic exageration, maybe 1 or 2 is more like it.
but 200 is seen on most guys clocks almost everyday, even delivery trucks do 180+
Australia's traffic moves so slow, I remember on a holiday to Japan myself and 2 friends all crammed into a 300ZX at about 7pm to see the sites. On the highway we were doing around 180-200km/h and cars on the right lane were flying past us going at least 280-300km/h it was crazy.
i never saw this when i was in japan.... only happens very late at night.
yes australias tarffic is very slow compared ot teh rets of the world, but there rd deaths are the lowest in the world
in south africa 500+ ppl die on the roads over the 2 week easter period
OMG :thumbsup:
http://www.atsb.gov.au/road/stats/holiday_periods.cfm
It was 12 here in Australia this year... Are the laws ever likely to change to reduce the road toll Neil?
Well firstly WOW dem south africans are, well interesting, foolhardy maybe the right choice of words, YES WOW it is AMAZING you got that little beast of yours up to that speed, I cant say the same thing about my car, but you have to understand drink driving is considered a very big no no here in AU, and a lot of people do not like to endorse it, I am one of them, but it is all about culture, SA have a different culture, not that we should persecute this young guy for wanting to show off, just kindly inform him that us Aussies do not like endorsing that kind of behaviour, simple!
OMG :thumbsup:
simple answer
Never, Not a chance, NO
there is so much corruption there that u can buy your way out of anything,
you can buy passports, Id books even drivers licenses,
unroadworthy cars can buy roadworthy certificates without the road worthy place even seeing the car.
the new governament has no control over anything,
ppl will do anything for money
everybody and everything has a price
carte blanche (a magazine tv program) took a scrap, smashed fu(ked car, that had to be put on a trailer, no engine no wheels nothign just a shell and they got a road worthy certificate for it.
the country is heading to be like zimbabwe
thats why south africans who can afford to leave the country come to places like australia
:thumbsup:
I've seen Barina's (in front of me) shake as a truck zooms past them on the highway
No offense Eug, but you obviously have not seen Neil's old Barina, I reckon you or I would be hard pressed keeping up with it, until we hit a long straight :)
well said cyrice, i think it is all about culture and a different way of life
like new zealanders and sheep, same thing :jk:
No offense Eug, but you obviously have not seen Neil's old Barina, I reckon you or I would be hard pressed keeping up with it, until we hit a long straight :thumbsup:
really? is it like that evo V with an excel shell?
btw, I was talking about normal old lady barinas :0
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
