Ok, i want to upgrade my standard turbo on my 32 gts-t. I've been thinking a 2nd hand GT2530 (any other suggestions). I don't want to spend over 2k.
I have a fmic, 3" zorst, pod, bov. Fuel pump, SAFC and fuel regulator on the way. Anyone recommend anything else i might need for the turbo upgrade before i wind up the boost?
Do i need to do injectors?
https://www.sau.com.au/forums/topic/41779-turbo-upgrade-for-r32-gts-t/
ecu i would say, get rid of the stock fuel and boost cuts etc..
i think you can run upto 1.3bar (not 100% sure) on the 2530 and your afm may max out at this level of boost too (unsure). if thats the case and you go for an ecu then you could get a z32 afm to work around the 5v max out of the air flow meter. whats your clutch like? :)
Yeah good thinking, the afm will need to be changed, thus i may as well not waste my time with an SAFC and just bite the ECU bullet. Power FC or Wolf guys?
The clutch is being worked on. Killing the stock clutch first. I've made this car a 7 month plan, ready for Christmas holidays.
How much hp can the stock rb20det injectors handle safely?
well the 33 turbo makes 190rwkw at 14psi, and another person has just made 200rwkw with the 2530 at 17psi...i'd go for something larger than the 2530 the gains dont seem to be all that good. having had 190rwkw it gets boring rather quickly
If budget is strictly 2k, then i would be looking at getting your turbo high flowed. It will bolt straight back on, use al the same piping and lines, and only additional cost will be radiator of coolant, 4L of oil and two new gaskets....that it, not another dollar to spend.
Be wary of buying a 2nd hand 2530, as there are a few little parts that need changing which all add to the cost (water/oil lines, inlet pipes), plus its a 2nd hand turbo and could have dramas which with a strict 2k budget means you have a nice souvenir but nothing to bolt onto your engine
Wise advice Roy, but i think im just going to have to take the chance and trust the supplier of the turbo. How much does high-flowing the standard turbo cost?
If someone could enlighten me on the high-flowing process of the standard RB20DET Turbo, that would be great.
