Ok, i want to upgrade my standard turbo on my 32 gts-t. I've been thinking a 2nd hand GT2530 (any other suggestions). I don't want to spend over 2k.
I have a fmic, 3" zorst, pod, bov. Fuel pump, SAFC and fuel regulator on the way. Anyone recommend anything else i might need for the turbo upgrade before i wind up the boost?
Do i need to do injectors?
https://www.sau.com.au/forums/topic/41779-turbo-upgrade-for-r32-gts-t/
ecu i would say, get rid of the stock fuel and boost cuts etc..
i think you can run upto 1.3bar (not 100% sure) on the 2530 and your afm may max out at this level of boost too (unsure). if thats the case and you go for an ecu then you could get a z32 afm to work around the 5v max out of the air flow meter. whats your clutch like? :)
Yeah good thinking, the afm will need to be changed, thus i may as well not waste my time with an SAFC and just bite the ECU bullet. Power FC or Wolf guys?
The clutch is being worked on. Killing the stock clutch first. I've made this car a 7 month plan, ready for Christmas holidays.
How much hp can the stock rb20det injectors handle safely?
well the 33 turbo makes 190rwkw at 14psi, and another person has just made 200rwkw with the 2530 at 17psi...i'd go for something larger than the 2530 the gains dont seem to be all that good. having had 190rwkw it gets boring rather quickly
If budget is strictly 2k, then i would be looking at getting your turbo high flowed. It will bolt straight back on, use al the same piping and lines, and only additional cost will be radiator of coolant, 4L of oil and two new gaskets....that it, not another dollar to spend.
Be wary of buying a 2nd hand 2530, as there are a few little parts that need changing which all add to the cost (water/oil lines, inlet pipes), plus its a 2nd hand turbo and could have dramas which with a strict 2k budget means you have a nice souvenir but nothing to bolt onto your engine
Wise advice Roy, but i think im just going to have to take the chance and trust the supplier of the turbo. How much does high-flowing the standard turbo cost?
If someone could enlighten me on the high-flowing process of the standard RB20DET Turbo, that would be great.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
