For sale is my r32 gtr but thinking of parting out if most parts are spoken for
engine
built by crd making 451kw on 98 pump fuel
JUN pistons + rods
JUN oil pump
all machine work done at crd
race ported head 1mm oversized valves
jun cams custom spec
crd 9 liter sump
all arp studs
post-103588-0-63769700-1358250044_thumb.jpgpost-103588-0-66416400-1358250027_thumb.jpg
ACC
hypertune plenum ,4'' throttlebody and header tank
hks 4'' drag cooler
hks gtrs turbos ,dump pipes
greddy piping kit
trust y pipe
reddy radiator and pipes
motec m800
1200cc injectors
hks fuel rail
sard (big version) reg
3x 044 pumps in custom tank
os giken 4rc
hks evc6
splitfire coil packs
r32 gtr 2 pac satin black with red pin stripe
has 17x9 volk gtp wheels are ready to be sent for reco and paint as one has slight gutter rash
andra spec 6 point crmo roll cage
parachute mounted to chasis
g4 brake kit
ohlins coilovers
carbon fibre bo clutch and lightened flywheel
post-103588-0-54138500-1358250013_thumb.jpgpost-103588-0-46894500-1358249999_thumb.jpg
car itself needs windows and seats put back in after cage install and paint job was done.
ot lid
there is way to much to list and iv forgot heaps but ill add in time
selling whole car for $29000
long motor $15000
all parts wont be for sale till enogh interest as i dont want half a car sitting in shed
selling due too i have too many projects and need the space so she has to go. have owed for 8 years brought in standard form built to run 9s and it the pics car is abit dusty dew too fibreglass place next door
call me on 0434050953 or pm
Ohlins ct6 not sure on price as wanting too sell the lot
Frosty pm me and I can send you a pic . As for the rules I don't think I was breaking any the whole car is for sale and it's just about impossible to every pic as I'm not on the dole or a uni student so time is a factor
  • 1 month later...
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
