Hi,
Just started a new R32 GTR Dedicated Rally Car build...
After putting Kermit into a concrete barrier in the rain last July, I am slowly getting the parts together to build another one..
Previous car straight after the "incident" with the wall at around 160 kph plus..
Then sourced the ex Brighty R32 GTR to use as the new donor shell c/w cage from Brad
Gave the shell a clean up-removed old stickers etc and then put on my trailer ready for Marc and Josh at C-Red to make it roll.. ready for Phil at AFM to ensure the chassis is straight-seam welding and panel and painting etc
Also purchased a Jun carbon fibre lip, CF wing and CF font grill as well as another set of original front guards/original bonnet and a new front radiator mount from Northside Nissan.
post-74499-0-47172000-1358252277_thumb.jpgpost-74499-0-66783900-1358252352_thumb.jpgpost-74499-0-28515900-1358252452_thumb.jpg
Once the car comes back from Phil at AFM ( panel and painted in the retro red white and blue Richards/Skaife livery)I will update with the mechanical details.
cheers
https://www.sau.com.au/forums/topic/417823-r32-gtr-drc-build/
  • 3 months later...
Interested to see how those door trims go. I have had my eye on them for quite a while but as you say, worried about them fouling on the side intrusion.
All looking great!
Hey,
Yeah, I have been looking at the Bee R door trims for a while and then one night after a few bourbs...I needed to have them....
I have attached a few shots I took this morning to give you an idea of what you get..( the doors are still off the new race car so I cant try them in situ yet...another week or so and i will find out)
The fit will clearly depend on the measurement between the intrusion bars and the actual body(ie: how wide the the tab is that is welded to the cage) if you follow me..
Drivers side and passenger side trims are around 50mm "thk"
Drivers side then slims down to around 30mm "thk"
Passenger side stays at around 50mm thk
Drivers side is about 30mm thk up in the top left corner, then blends up to 50mm thk as you get close to the door handle.
Note that both trims are 50mm at the top where they hook over the door....
Passenger is 30mm thk at top right corner then steps up another 20mm ( which makes it a pretty contant 50mm thk)
Driver top left corner
Driver bottom left
50mm thk where they hook over the door
Legendary! Thanks for posting this up will get the measuring tape out.
I wondered what happened to that car. Good to see it'll be revived.
Subscribed! Looking forward to seeing the old girl go round again!
You doing much racing these days? In a new car?
  • 2 months later...
  • 2 months later...
The car is now being set-up for 'Improved "Production Circuit Racing"
Going forward, I will keep a more up to date status of the build on my "basic" website..
ie:
It covers the previousTarmac Rally car info and the new build Improved Production car build as well as a sponsorship page
www.deleeuwracing.wordpress.com
  • 1 month later...
  • 1 month later...
Hey,
Its a no go to start with.....pretty expensive to just put them on a streeter etc so I am just about to "try" a couple of things with some mild heat and try to shape them in a couple of places....the drivers side just "touches" the cross bars so a smidge of heat just might do the trick ......but the passenger side( which has different shape-profile) might be a litlle trickier to re shape.....
I will let you know in the necxt couple of weeks.....
cheers
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
