There's likely a tell in the VIN number but failing that, post VIN in the "FAST" thread in the General Auto Forum and someone will tell you if it's a genuine 260.
Again, unless you have a real boner for 260's, you'll get much, much better value out of an S2 RS4S.
Mines got almost 130,000 on the clock, heaven knows how many it's actually got, but it's holding up fine. It's got the standard rust under the left side mirror (common) and has had the rear wheel bearings replaced as well as the coils (also both common). Aside from that it's still tip top and holding up well. There's minimal wear and tear on the interior and not much in the way of rattles and squeaks.
It's also had pretty much all the suspension replaced with whitealine/bilsteins so I'm not sure how it'd feel if it still had the original on it (which I have in the shed and it all looks fine - no leaks or anything).
Edited by Cowboy1600
I have a real boner for the RB26, so the 260RS is appealing. Ideally I would like a GTR, but with 2 kids under 4, four doors and the storage space of the Stag tick the boxes.
The 260RS I'm looking at is a very good price, so the cost differance isn't an issue
Any clues as to the tell in the VIN number?
Fair enough.
I've got a 10 month old so the R33 went and was replaced by the Stag. My wife hates it (low, hard to get in and out of, bumpy, too fast etc etc) but I love it. I've also always loved station-wagons.
No idea if and what the tell might be but I'm sure someone will chime in.
One other thing, if the price is "good" then it's possible the car isn't. Remember, if it's too good to be true then it probably is. There should be a fairly significant price difference between a 260 and S2 C34 should you be comparing like for like.
Yeah understand all that, having ownded a R32 for ages and modding it tastefully without it ever busting - and it still going strong now over a decade later I know what to look for mechanically etc.
Haven't seen it in the metal yet, just pics etc, thanks for the input. Hope the thread starter doesn't mind the contribution, as it was about the 260RS I thought it was all relevant
heres some pics for ya. took me a while to figure out how to post the bloody things.
forgot to add that they had to drop the exhaust an inch to be able to fit the mount on the chassis
Edited by oscillo hero
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
