There's likely a tell in the VIN number but failing that, post VIN in the "FAST" thread in the General Auto Forum and someone will tell you if it's a genuine 260.
Again, unless you have a real boner for 260's, you'll get much, much better value out of an S2 RS4S.
Mines got almost 130,000 on the clock, heaven knows how many it's actually got, but it's holding up fine. It's got the standard rust under the left side mirror (common) and has had the rear wheel bearings replaced as well as the coils (also both common). Aside from that it's still tip top and holding up well. There's minimal wear and tear on the interior and not much in the way of rattles and squeaks.
It's also had pretty much all the suspension replaced with whitealine/bilsteins so I'm not sure how it'd feel if it still had the original on it (which I have in the shed and it all looks fine - no leaks or anything).
Edited by Cowboy1600
I have a real boner for the RB26, so the 260RS is appealing. Ideally I would like a GTR, but with 2 kids under 4, four doors and the storage space of the Stag tick the boxes.
The 260RS I'm looking at is a very good price, so the cost differance isn't an issue
Any clues as to the tell in the VIN number?
Fair enough.
I've got a 10 month old so the R33 went and was replaced by the Stag. My wife hates it (low, hard to get in and out of, bumpy, too fast etc etc) but I love it. I've also always loved station-wagons.
No idea if and what the tell might be but I'm sure someone will chime in.
One other thing, if the price is "good" then it's possible the car isn't. Remember, if it's too good to be true then it probably is. There should be a fairly significant price difference between a 260 and S2 C34 should you be comparing like for like.
Yeah understand all that, having ownded a R32 for ages and modding it tastefully without it ever busting - and it still going strong now over a decade later I know what to look for mechanically etc.
Haven't seen it in the metal yet, just pics etc, thanks for the input. Hope the thread starter doesn't mind the contribution, as it was about the 260RS I thought it was all relevant
heres some pics for ya. took me a while to figure out how to post the bloody things.
forgot to add that they had to drop the exhaust an inch to be able to fit the mount on the chassis
Edited by oscillo hero
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
