I just love the sound of chalk scraping across the blackboard :yes:
I was sad that you didnt show up to watch me scrape off the ferry!!! the irony is i got on and off the ferry with no scraping at all and my front lip is under 100mm i think and then i scrubbed out going into the car park for the kiosk!!
Was a great cruise, i got stuck behind a commonwhore and had to slow right down to almost a crawl through the twisites, this was most frustrating but other then that it was awesome, the run home was a blast open roads no commodores to slow us down to 40km in the corners!!! :rofl2:
Wow! Safe embarkation & disembark'n huh?
People can say to me now, "I told you so!" lol
I'm finishing off a detail on the Forester - it's getting sold next Sat - so; sorry Adam.
Yeh i was quite suprised myself that i didnt scrape on/off, they even stuck me on the smaller ferry that is even worse and i crab walked on and off, I hope the next one you can make it, would love to see that perfect N1 of urs :wub:
Hey 1st pic - with trepidation !
Thanks about the N1 Adam.
It'll be displayed on 5/7/13 at our free Tech Night #3.
Can't tell what or where it is yet because #2 is yet to be announced for Wed 24/4/13. And the topic of that one will be release on March 1st.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
