Just wondering how long it takes your car to reach normal operating temp from a cold start under normal (no lead foot) drive?
I've got a stock as a rock R34 GTT apart from an apexi pod...it takes under 60 secs to reach the half way mark on my engine temp gauge. Using Cusco 5w 40 oil.
Cheers
It should probably take a little bit longer than that, but these hot days may be causing it to come up to temp a bit quicker. I'm assuming that is while you are driving? In which case how you drive will also play a part.
If that is 60 seconds of idling then unless it is super hot where you are, that is a little bit on the quick side as it takes longer when idling.
I should add that it may just be that the gauge is just a little bit happy and there is nothing wrong with the cooling system. The gauge gets to the normal point from about 65 degrees and above
yeah mine takes not long at all really. driving at suburban speeds maybe about 2mins and its up to temp or if i start it up and jump straight onto the open road (100kph) it comes up real quick yeah maybe 60 seconds
Before with my almost dead thermostat, it would take 20+ mins.
But after swapping over to a new one, it'll take roughly around 2-3kms @ 60km/h.
As mad082 said, it really depends on the weather as well. If it's a really hot day, then the thermostat will open a lot sooner versus a cold night where it'll stay closed for longer so the engine can warm up properly.
Thats only coolant, temperature,
+1, so you shouldnt use that as an indicator that its ready to be driven hard. You want the oil temp to be normal before you do that, and it takes a lot longer.
i must have somthing wrong then, according to the power fc, im at approx 50degrees within 5min. living on acreage it can take that long to get out the front gate with a toddler getting his seatbelt on, lol, then after 5-10min at 60-80k/hr im upto high 70's,
do you guys recommend a standard thermostat or aftermarket? and what coolant temp is considered the normal?
Edited by AngryRBGTX
82 degrees is normal. and definitely go standard. go genuine nissan. you can buy plenty of aftermarket ones with lower temps, but they are a waste of time and money, partly because they will make you use more fuel.
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
