E85. It was your recommendation actually from a previous thread. I ditched the 34 as Roy said 33's are Iighter, so I bought a 33. Simon made good power with his 25 so I stuck with a 25. You said FP HTA3076 + 6boost so I went that way.
No good asking questions if you don't listen to the answers.
It's track only so will be pushed hard.
I'm keen too on results, keen to see what she'll make.
There's a built 25 with 6boost + FP 3076 about to hit the rollers.......
Should this have been interpreted to mean that results were going to be posted shortly - or should I start breathing again? :D
Sorry but you'll have to wait about 3 weeks. Turbo should land Thursday, then dummy fit for dump before all going off to Crave for some ceramic coating. First event is 2-3 March so got a bit to do yet before then.
That is cool :D
I forgot to ask, is your RB25 running upgraded cams? Plenum? And what size fuel system? Gotta set myself up for what to expect hahaha.
Tomei PonCams, FFP, minor port/polish, full supertech valvetrain with os exh valves, E85, twin pumps.....all the fruit required to be a fairly decent 25.
My budget build sort of got lost along the way.. :whistling:
No kidding. I hope it pays off! Should make good power, though I'm really looking forward to seeing the power delivery and hearing how it drives - it should be a bit of a beast.
If all goes to plan a friend of mine will have a decent result to contribute also as a comparison.
VQ25DET with FP3076HTA, .82 Tial Vband
Im helping a lot with the thought process and (like lithium) hope it works out well! LOL
Is this in a Stagea? I was hoping someone would do an engine conversion into something with a decent amount of room, without the cramped stock manifolds...
Should be interesting to compare to my results. Staying auto?
Can tell you its not in a stag but im gunna bite my tongue and let Jase tell the details :whistling:
Is going into an S15 with stock manifolds and Z33 6 speeder :banana:
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
