Awesome - sounds good, so it has met your expectations without even leaning on it then? Hope the power delivery/response is good too :) I had figured it could be good for 450kw+ @ hubs on the right setup, but Dyno Dynamics are a bit of a mystery to me - never had any direct exposure to them so really I wasn't sure what to expect on one of those, though I had expected 370kw should be pretty doable.
Wow so it's not going to be driven at all until race day? No pressure :mellow: Hope it all goes well!
  • 1 month later...
Back to the FP3794HTA - apparently Forced Performance have a prototype "FPxx94HTA" which uses the same compressor wheel as the FP3794HTA but has different housings and a different turbine wheel, the initial indications are that it is expected to spool quicker than the current PT6766 and FP3794HTA - but make more power than either.
The car that the testing this thread is about has had one of these units attached to it and will be getting it tuned soon - and no doubt they won't be holding back. if it If it does turn out to be a better all around performer than the best of the 6766 and 3794 combined then it is a hell of a thing :)
It is Boostin' Performance's AWD Eagle Talon - it runs a high compression 4G63 with lots of headwork etc etc. It has run into the low 8s at >170mph (ie, quicker and faster than plenty AWD cars with GT42s/GT45s etc have run) with both the PT6766 and the FP 3794HTA, so it is a good base for taking such a turbo to it's limit :)
  • 3 weeks later...
  • 3 weeks later...
More on this GT3794R HTA prototype, it is now released as the Super94HTA and apparently spools better than and makes more power than both the PT6766 and the GT3794R HTA... it has been tested on a Mitsi AWD drag car which has run the previous turbos and on a slippery track this weekend it ran 8.4 @ 177mph - huge MPH for a car running a T3 based turbo.
So anyone certifiable who was looking for something in the 6766/3794 size range - they are now available to buy:
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTFPSUPER94&Category_Code=Turbo-FP
  • 4 months later...
  On 09/10/2013 at 6:06 AM, jet_r31 said:
^^give it a rest dude, lol, 400 threads
cheers
darren
Great quote there wanna-be mod. Try 4/5 posts over 5 days....
First 7s car I am aware of running a single T3 turbo, using a .85a/r FP Super 99HTZ:
And an AWD DSM ran a 1000ft test run this weekend and lifted to hit 8.2 at 153mph also using an HTA - they only had an 8.5 certified cage and had suspected they MIGHT go too fast, hence lifting at 1000ft.... but were kicked out due to still going way too quick. Seems like there may be a couple of 7s AWDs and a number of low 8s ones running these turbos in the near future :)
Agreed, just pointing out it is still a large turbo - but it is SERIOUS business... especially when no one has pushed a 99HTZ to it's limits, yet.
  • Like 1
A Supra owner in the US has upgraded from their old Borg Warner S467 T4 turbo to a T3 flanged FP Super99HTZ and picked up 15% more power with a huge increase in spool - they run a Powerglide and usually use a transbrake however they are testing for an event this weekend where the class they will be in doesn't allow transbrakes, so they did testing using a foot brake starting at low boost to see how much they could hold back with the foot brake and have already laid down a 8.97 @ 151mph... I suspect when they get to a meet they can use the transbrake and wind up the boost a few eyebrows will be raised - not that running 8s on a T3 based turbo with a Supra isn't pretty unreal as it is!
  • Like 1
Not with the new turbo yet, today it was it's first runs - the turbo seems to have maxed out at about 36psi (with 280deg cams) but I don't know what boost it was running for the 8 - definitely not 36psi.
Here's a dyno vid (unfortunately they only uploaded to FB): https://www.facebook.com/photo.php?v=194348620749465&set=vb.173984302785897&type=2&theater'>https://www.facebook.com/photo.php?v=194348620749465&set=vb.173984302785897&type=2&theater
Dyno numbers will be a bit messed up due to the loose Powerglide - but a Supra running 8s at >150mph is going to be making north of 900hp to start with, it isn't running NOS and it did it off the foot brake with more boost in it.... so safe to say that it's already a pretty stout result :)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
