Awesome - sounds good, so it has met your expectations without even leaning on it then? Hope the power delivery/response is good too :) I had figured it could be good for 450kw+ @ hubs on the right setup, but Dyno Dynamics are a bit of a mystery to me - never had any direct exposure to them so really I wasn't sure what to expect on one of those, though I had expected 370kw should be pretty doable.
Wow so it's not going to be driven at all until race day? No pressure :mellow: Hope it all goes well!
  • 1 month later...
Back to the FP3794HTA - apparently Forced Performance have a prototype "FPxx94HTA" which uses the same compressor wheel as the FP3794HTA but has different housings and a different turbine wheel, the initial indications are that it is expected to spool quicker than the current PT6766 and FP3794HTA - but make more power than either.
The car that the testing this thread is about has had one of these units attached to it and will be getting it tuned soon - and no doubt they won't be holding back. if it If it does turn out to be a better all around performer than the best of the 6766 and 3794 combined then it is a hell of a thing :)
It is Boostin' Performance's AWD Eagle Talon - it runs a high compression 4G63 with lots of headwork etc etc. It has run into the low 8s at >170mph (ie, quicker and faster than plenty AWD cars with GT42s/GT45s etc have run) with both the PT6766 and the FP 3794HTA, so it is a good base for taking such a turbo to it's limit :)
  • 3 weeks later...
  • 3 weeks later...
More on this GT3794R HTA prototype, it is now released as the Super94HTA and apparently spools better than and makes more power than both the PT6766 and the GT3794R HTA... it has been tested on a Mitsi AWD drag car which has run the previous turbos and on a slippery track this weekend it ran 8.4 @ 177mph - huge MPH for a car running a T3 based turbo.
So anyone certifiable who was looking for something in the 6766/3794 size range - they are now available to buy:
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=PROD&Store_Code=FP&Product_Code=NTFPSUPER94&Category_Code=Turbo-FP
  • 4 months later...
First 7s car I am aware of running a single T3 turbo, using a .85a/r FP Super 99HTZ:
And an AWD DSM ran a 1000ft test run this weekend and lifted to hit 8.2 at 153mph also using an HTA - they only had an 8.5 certified cage and had suspected they MIGHT go too fast, hence lifting at 1000ft.... but were kicked out due to still going way too quick. Seems like there may be a couple of 7s AWDs and a number of low 8s ones running these turbos in the near future :)
Agreed, just pointing out it is still a large turbo - but it is SERIOUS business... especially when no one has pushed a 99HTZ to it's limits, yet.
  • Like 1
A Supra owner in the US has upgraded from their old Borg Warner S467 T4 turbo to a T3 flanged FP Super99HTZ and picked up 15% more power with a huge increase in spool - they run a Powerglide and usually use a transbrake however they are testing for an event this weekend where the class they will be in doesn't allow transbrakes, so they did testing using a foot brake starting at low boost to see how much they could hold back with the foot brake and have already laid down a 8.97 @ 151mph... I suspect when they get to a meet they can use the transbrake and wind up the boost a few eyebrows will be raised - not that running 8s on a T3 based turbo with a Supra isn't pretty unreal as it is!
  • Like 1
Not with the new turbo yet, today it was it's first runs - the turbo seems to have maxed out at about 36psi (with 280deg cams) but I don't know what boost it was running for the 8 - definitely not 36psi.
Here's a dyno vid (unfortunately they only uploaded to FB): https://www.facebook.com/photo.php?v=194348620749465&set=vb.173984302785897&type=2&theater'>https://www.facebook.com/photo.php?v=194348620749465&set=vb.173984302785897&type=2&theater
Dyno numbers will be a bit messed up due to the loose Powerglide - but a Supra running 8s at >150mph is going to be making north of 900hp to start with, it isn't running NOS and it did it off the foot brake with more boost in it.... so safe to say that it's already a pretty stout result :)
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
