  • Replies 87
Also have the following:
Used N1 oil pump approx. 27xxxkms. Only removed as replaced with a nitto item. Works perfectly fine. $100ono
also have used charcoal cannister. $100ono.
Make some offers guys, im fairly easy.....
Aircon gear now sold.
Rest is still up for grabs. Open to offers people....within reason of course.
Bonnet now gone.
Still got the TE37s and a few other bits and pieces.
Like i said, im open to offers within reason.
Come on guys, chuck me some offers.
Need to clear some room in the garage.
Perfectly good set of TEs waiting for a new home.
OK ladies and gents.
Starting tonight and ending next sunday (21/4), ill take off 20% of the prices i have up here.
Thats $1600 for a set of TE37s
$800 for a rb26 head
$400 for a lightly used set of accralite forgies with standard rods (extremely light)
Motivated to move this stuff guys and girls.
No holding items, first in with cash gets it.
Aaaaaaaaaaannnnnnddddddd GO!
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
    • It just depends if you're like me with a high level of OCD for doing something like hardlines, and highly critical of the little things, and then bugger all patience to get it how my brain pictures it
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
