  • 3 weeks later...
  • Replies 87
Need room in the garage. Make us some offers guys. Pretty motivated to get this stuff gone.
  • 4 weeks later...
  • 1 month later...
Guys, throw some low balls at me if you want.
You never know your luck.
Need to get this stuff gone!!
  • 1 month later...
  • 1 month later...
  • 4 months later...
  • 4 weeks later...
Hey all, need rb26 valves for R33! Please pm or text 0406247260 if you have or know where I can get them. thanks
Sorry sweetness, you wont find them in this thread because I dont have any for sale individually.... Unless you wana buy my used rb26 complete head.
Poor Bastard, head still for sale and price?
Yeah its still for sale. $500 plus delivery or pick up near Wollongong NSW.
Its a standard head from a 32 GTR, it is complete and includes everything except covers and coils.
It has been sitting for a few years and will need to be reconditioned and has a slight indentation on no6, but nothing that is detrimental to the head itself.
Can send pics to your mobile if you wana PM me your number if you are interested.
  • 5 months later...
Just a bit of an update on what I have left:
Pair of standard R32 GTR turbos in good condition $300
Pair of T517z turbos, one probably needs a seal kit as it was a bit smokey, otherwise still ran well SOLD
R32 GTR 3" exhaust (unknown brand), also comes with 3" straight through pipe and v band style clamp for a quick swap out from quiet to loud in 5 mins SOLD
R32 GTR front pipe, 2.5 - 3" (unknown brand) SOLD
R32 GTR standard manifolds $50 each
R32 GTR manifold heat sheilds $20 each
Nismo 555cc injectors, good condition SOLD
R32 GTR fuel rail and reg (standard) $100
R32 GTR fuel rail $50
Nismo fuel reg SOLD
Tomei Sump baffle SOLD
RB26 86.5mm Accralite forged pistons (used), good condition, comes with a set of standard rods (will not separate) $500
RB26 twin turbo pipe $100
RB26 head (standard), NO COVERS OR CAMS , slight indentation on no6, will need a refresh as its been sitting for a while $500
RB26 intake manifold with itb's and sandwich plate $500
Apexi pods with afm adaptors and brackets SOLD
R32 GTR afm's (one was opened to fix a solder joint, works perfectly fine) SOLD
R32 GTR Cusco tension rod brace $100
R32 GTR front sway bar (standard) $100
HKS metal exhaust manifold gaskets, good condition $50
R32 GTR charcoal canister $50
RB26 various intake pipes (standard) from $10
R32 GTR air con ducting (everything from under the dash to under the carpet, bar i piece that goes to driver side round vent) $50
Will post at buyers expense, or pick up near Wollongong NSW.
All items are "or nearest off"
If you want pics, please inbox me.
  • 1 month later...
should change your mind on the te37s and send me a pic
Sorry man, the sit too nicely over my brake kit. I didnt think they would fit over originally, but happen to do so perfectly.
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
