  • 4 weeks later...
  • Replies 87
  • 1 month later...
Cusco tension rod brace, accralite forgies, head, charcoal canister and HKS exhaust gaskets all SOLD!!
Just a bit of an update on what I have left:
Pair of standard R32 GTR turbos in good condition $300
Pair of T517z turbos, one probably needs a seal kit as it was a bit smokey, otherwise still ran well SOLD
R32 GTR 3" exhaust (unknown brand), also comes with 3" straight through pipe and v band style clamp for a quick swap out from quiet to loud in 5 mins SOLD
R32 GTR front pipe, 2.5 - 3" (unknown brand) SOLD
R32 GTR standard manifolds $50 each
R32 GTR manifold heat sheilds $20 each
Nismo 555cc injectors, good condition SOLD
R32 GTR fuel rail and reg (standard)
SOLD
R32 GTR fuel rail $50
Nismo fuel reg SOLD
Tomei Sump baffle SOLD
RB26 86.5mm Accralite forged pistons (used), good condition, comes with a set of standard rods (will not separate)
SOLD
RB26 twin turbo pipe $100
RB26 head (standard), NO COVERS OR CAMS , slight indentation on no6, will need a refresh as its been sitting for a while
SOLD
RB26 intake manifold with itb's and sandwich plate SOLD
Used standard coil packs $100
Used splitfire coilpacks $350
Apexi pods with afm adaptors and brackets SOLD
R32 GTR afm's (one was opened to fix a solder joint, works perfectly fine) SOLD
R32 GTR Cusco tension rod brace
SOLD
R32 GTR front sway bar (standard) $100
HKS metal exhaust manifold gaskets, good condition
SOLD
R32 GTR charcoal canister SOLD
RB26 various intake pipes (standard) from $10
R32 GTR air con ducting (everything from under the dash to under the carpet, bar i piece that goes to driver side round vent) $50
Will post at buyers expense, or pick up near Wollongong NSW.
All items are "or nearest off"
If you want pics, please inbox me.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
