Hi All,
Shopping for slotted rotors for my R34 GTR.
Was hoping someone could point me in the direction of a supplier that still has the DBA 4000 old wiper slot pattern if possible.
Maybe someone still has old stock etc remaining on the shelf?
Just a personal preference, however if necessary will settle for the new style design.
Thanks.
Old design -
New design -
When new models come out, like most things, the old stock is returned to the manufacturer or sold on 'special' to clear and rebates given.
You'll have a hard time finding them in most instances. What business wants to carry old stock when customers want new stuff? :)
The old design was prone to cracking when pushed. It makes no sense to try to get the flawed design now that its been superceeded with a better design.
^^^ this
Adam recalls how these were prone to cracking.
Any slots that go to the edge, and at right angles to the edge, are prone to cracking.
It's the same principle where...
* a glass cutter needs to go right to the edge for glass to crack - if it doesn't it's hard to snap
* a tablet that is scored across the middle to enable a 1/2 dose needs the scoring to go to the edge to facilitate cracking
So you wouldn't want to have your rotor slots anywhere near the edge; or worse still, perpendicular to the edge.
The "NEW OLD" model fixed this problem, the slots stop before the edge by around 5mm, on the front anyway, and I never heard of anyone having problems with the rears.
Skylines are far too front heavy for the rears to get the same level of heat/cracking going on.
Most people will replace the fronts twice before even touching the rears once in most cases.
    • This is a very much loved and well looked after car! - Regularly serviced and maintained - Smooth and reliable to drive - Premium model with Bose speakers, suede/leather seats, and dual climate control - Kenwood Double din DMX7522DABS stereo with USB Mirroring, Android Auto/Apple Carplay, DABS radio - 6 Cylinders 3.5L Engine -Triptronic sports automatic - 11000kms - Pearl White - Registered until August - Small fixable dent on boot and several scuff marks/paint chips.
    • Swapped the injectors around and the misfire followed. I went ahead and ordered the Deatschwerks 550cc injectors and am currently waiting for them to be ship and arrive. In the meantime, I've had my Nistune soldered to the ECU. Tested it, and and tried it out with the software. Everything should be prepared for when the injectors arrive.
    • Yeah they charge a little extra for mods , last year I noted no mods but I did have an exhaust fitted after that so  better to let them know cause these kinds of things can cause the policy to be void if you ever need to claim.
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
