Hi All,
Shopping for slotted rotors for my R34 GTR.
Was hoping someone could point me in the direction of a supplier that still has the DBA 4000 old wiper slot pattern if possible.
Maybe someone still has old stock etc remaining on the shelf?
Just a personal preference, however if necessary will settle for the new style design.
Thanks.
Old design -
New design -
When new models come out, like most things, the old stock is returned to the manufacturer or sold on 'special' to clear and rebates given.
You'll have a hard time finding them in most instances. What business wants to carry old stock when customers want new stuff? :)
The old design was prone to cracking when pushed. It makes no sense to try to get the flawed design now that its been superceeded with a better design.
^^^ this
Adam recalls how these were prone to cracking.
Any slots that go to the edge, and at right angles to the edge, are prone to cracking.
It's the same principle where...
* a glass cutter needs to go right to the edge for glass to crack - if it doesn't it's hard to snap
* a tablet that is scored across the middle to enable a 1/2 dose needs the scoring to go to the edge to facilitate cracking
So you wouldn't want to have your rotor slots anywhere near the edge; or worse still, perpendicular to the edge.
The "NEW OLD" model fixed this problem, the slots stop before the edge by around 5mm, on the front anyway, and I never heard of anyone having problems with the rears.
Skylines are far too front heavy for the rears to get the same level of heat/cracking going on.
Most people will replace the fronts twice before even touching the rears once in most cases.
    • EDIT: Just a little info what my tranny is "doing" :   For the long time the trans do this "bad" sound:https://www.youtube.com/watch?v=qs_iTXgDt40 It is literally the same sound and same symptoms(when i push the clutch it quites down) So is it really the shaft bearing?   Also:  i found this on forums: The RB20 and SR20 boxes are nearly indentical inside (rb20 has longer mainshaft)and suffer badly from bearing and selector failures when driven hard   The bearing is true and selector failure kinda too...it is "harder" to get into gears specialy when i drive a little bit hard...
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
