Hi guys
Time to clean out all the extra parts i have laying around the garage
All items located at Prestons Sydney, im not shipping this stuff so its pick up only
As stated in title this stuff is already cheap so some stuff im not neg on
First up
3.5" to 3" inch Catalytic converter, Has the usualy scratches on the underside but internally its %100 $50
next is a Greddy Y pipe (excellent for those guys doing a single mount single) good condition and comes with 2 silicon adapters with step downs for filters. Bought this for $200, selling it for $140
Standard R32 GTR wing .. one of its mounting bolts spins in its housing but be fixed with not too much difficulty.. apart from that just needs a wipe down and is in good condition with a few small scratches $50
Next is some standard parts
6x coil packs and ignitor.. started to misfire at 350rwkw so these would be good as a replacement for anything around 300rwkw and under
Ignitor $30
Coil packs $60
Blue Radiator hoses with 4 beefy clamps to suit GTR.. in good condition, just a bit dirty and need a wipe down $25
Some random BOV and turbo pluming from my old twin set up.. all in good condition. also have the BOV cross over pipe as is seen in the picture with the GTR wing.. Enquire for pricing, will still sell for cheap :D
Standard GTR Charcoal Canister for you emission nuts ;) $30
Standard R32 GTR intercooler... has a few bent fins and dings but works perfectly fine.. painted black..want it gone!! $30
Standard R32 GTR Manifolds.. good condition, would be ideal for someone wanting to do some porting $25
Standard GTR rods and pistons.. all rods are in good conditon, one of the pistons is fooked!! whole lot for $30
if theres more ill update
PM or message me 0432528844
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
