Description
For sale is a set of black Volk RE30s. These forged wheels are super light! I'm selling as I'm looking to upgrade to a slightly more aggressive setup.
Black VOlk RE30
5x114.3
18x8.5 +30
225/40/R18 Bridgestone Potenza RE001
Incluides Volk centre caps.
Condition
The wheels are in exceptional condition as pictures suggest. The only imperfection is a light graze (20mm) on one of the wheels.
Tyres are roadworthy with approx 70% tread left
Price
$2700ono (will post)
I am open to trades to 18" TE37s, CE28Ns (imust be more aggresive than size 18x9.5 +22)
Wheel #1
Wheel #2
Wheel #3
Wheel #4
https://www.sau.com.au/forums/topic/417913-black-volk-re30-18-re001-tyres/
