Hey guys,
I am currently looking at buying a 1993 r32 gtr vspec. i just want to know if and how to make sure its a legit vspec?! Has brembo brakes yes, its navy blue in colour; is that a factory colour? Is there a way to tell using the vin or model numbers?
if someone could help would be much appreciated!
Vin: 6U9000BNR32301976
Model: KBNR32RBFS NA
Need to know asap!!
https://www.sau.com.au/forums/topic/417920-r32-gtr-vspec/
As above, have someone run it through FAST. However looking at the model code you've given us, this should come up as a legitimate V-Spec, as they, and the V-Spec II models ended with RBFS as opposed to RXFS on a regular R32 GT-R. Midnight blue was a factory colour for the R32 GT-Rs. Quite a rare find, especially in the V-Spec variant.
Edited by Supah
https://www.sau.com.au/forums/topic/417920-r32-gtr-vspec/#findComment-6709683
Well hopefully its legit. the colour turns out to be TH1 which is Dark blue pearl.
Which is a legit factory colour.
But Grey / Black / White / Sliver were more common hence a rarity seeing a V-Spec II in Dark Blue Pearl.
https://www.sau.com.au/forums/topic/417920-r32-gtr-vspec/#findComment-6710566
Need to know asap!!
From Hadouken's links, my understanding:
The GTR you are looking at has Model Number: KBNR32RBFS NA
Judging from the Decode Chart, the "B" = V-Spec.
If it were a non V-Spec the Model Number should read: KBNR32RXFS, it will have a "X" (Example Only).
Then there is "NA"... With further searching I found:
N = Rear Spoiler Less
A = Standard
Meaning it came standard with no spoiler...
You might want to post a pic of the actual Blue Plate from the car you are looking at and post it here to clarify exactly if it's "NA" at the end.
https://www.sau.com.au/forums/topic/417920-r32-gtr-vspec/#findComment-6711929
A = Standard
How very help full!!! Thanks heaps!! yeah ill get the pic again and put it up!
https://www.sau.com.au/forums/topic/417920-r32-gtr-vspec/#findComment-6715969
  • 3 weeks later...
Hi JB4U33,
Nice find. If you happen to buy it be sure to add your details to the register of R32 V-Specs at http://www.skylinesa...spec-ii-models/
Hadouken gave you a link to my thread about V-spec vs standard GT-R differences (http://www.skylinesa...s-advice-to-me/) - FYI I'm about to send a follow up letter to Nissan Japan regarding the differences between the ATESSA control module for the V-spec and standard GT-R. Watch that space.
Cheers!
Mike
https://www.sau.com.au/forums/topic/417920-r32-gtr-vspec/#findComment-6739193
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
