  • Replies 51
Yep I have a fibreglass Nismo copy lip on my oem bar - even though my car is only slightly lowered I smack it on things and have cracked it. Looked awesome when it was new though!
Real carbon fibre ones can be had out of the USA for 'reasonable' money these days.
Do you have a pic of it on your car in its current state Andrew?
Was looking at getting one but if its completely munted after a few months, probably not. However if they aren't really noticeable marks, then could be tempted.
Thats a picture of an aftermarket Polyu. lip. Added a bit of niceness to the front, without sacrficing extra lowness at the front. (Car is also on coilovers) does scrape on some places, however, if youre careful it doesnt.
Think its the same one as the the link below, been toying with the idea of getting one myself.
http://www.ebay.com/...e2f8264&vxp=mtr
This is essentially identical to mine. It fit well, im just lucky I had a decent panel guy to sort it out. The material was sturdy, the fitment, like all other aftermarket body parts wasnt 100%, but its pretty close, and I dont even notice it anymore. Just used 4 tech screws and some sickaflex (note, this stuff will almost guaranteed not come off afterwards)
Andrew, you should go the URAS splitter just like RainbowBrite - http://www.luxury4play.com/asian-auto/98873-new-lip-rainbow-brite-g35.html
Your car is super low and i think this would look super awesome on your black on black setup - http://www.uras.co.jp/
Thanks everyone! And I should finally get around to some shots of the car... one day
Mayo, you're always dead-on with design ideas mate: URAS looks like the way to go... gotta brush on my Japanese to order it it seems though. Any particular reason they are so rare?
Currently my front looks like Nightcrawlers with a factory lip, think it will look mean with the URAS splitter under it.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
