Have done a search and didn't find a definite answer.
I am wondering what the length is or even just shortened/lengthened for RB25 gearbox into R32 (specifically 4door, if there's a difference?)
I realise I need a 25 yoke for the tailshaft but can anyone give me anymore info regarding the conversion? As I've read a few contradictory threads about it.
Cheers
https://www.sau.com.au/forums/topic/417936-tailshaft-length-for-25-box-in-r32/
You don't even need to know. Just front up to any decent tailshaft place. You possibly won't even need to tell them what you want. If you hand them a full R32 tailshaft and the front half of an RB25 one, they'll already know what you want and just do it. They will have done it 3 times that week already, even if you arrive on a Monday.
  • 3 weeks later...
Sorry to say but you are wrong. Rang up hardy spicer today and apparently they don't keep records and guess what it's a Monday also.
Anyone with any useful information that could help me out?
His point wasnt that there is an exact length for every car and that they would be able to rattle it off to you.
Each car (depending on how the box is sitting in the car) will need some slight adjustment. Sure there might be a ballpark length, but do you really want to get it farbicated to this length to find its too short/long?
As GTSBoy said, take the whole lot to a tailshaft/driveshaft place (Hardy Spicer is an example) and get them to do the work for you based of how the assembly is sitting in your car.
Edited by R32Abuser
Spicers are a bit random. I did say "any decent tailshaft place". I don't think we got Spicers to do mine. You could take your tailshaft bits to FoursNMore at Pooraka and get Brenton to sort it out for you. His story about how mine got done reads EXACTLY as I wrote in my first post. We took measurements of distance from gearbox extension to centre bearing bolt holes, he took the parts to the tailshaft place, guy at the counter gave the "oh, another RB25 into R32" shrug and went away and did it.
The only problem we had is that the tailshaft joints in Adelaide are sometimes so busy that you can't get anything done for weeks at a time.
Got basically the same story from Adelaide Tailshaft Services aswel that they only make them up if you provide measurements, didn't think it would vary from car to car so much and assumed they kept records also. Will have to measure it all up once gearbox is in it seems.
Anyone able to shed any light on what clutch master/crossmember to use? Always find more hurdles with modifying cars it seems ;)
Same clutch master is fine. Trans crossmember is harder. There are three types, marked A, B and C. They are mix-matched across various cars depending on which gearbox is in there. For example, the R32 auto uses a different one to the R32 manual. I can't remember which is which and I'm not going to try sliding under my car to tell you which one I've got in there!!! If you get hold of one of each, you should just be able to throw it in the car on the day.
Clutch slave sorry, makes sense R32 one doesn't bolt up to R33 bellhousing so will need an R33 unit obviously.
I have an A and C, apparently it's different converting auto to manual or manual 20 box to 25 box so guess there is no definite answer but hopefully one of the two I have bolt up
I went from R32 auto to manual and had to change crossmember. Then RB25 box transplant and had to change crossmember. I have a strong suspicion that I have the same type under there now as when it was RB20 auto. If that helps. Won't help if yours is a manual body.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
