CA18, 180-190rwkw, stock clutch, track car.
Pedal has stopped returning all the way to the top. Clutch feels like it's engaging OK, though there has been a few grinds due to mis-shift since it started playing up. Video shows how much freeplay is in the pedal before the master starts engaging. Plenty of fluid in the master, does not appear to be any leak on the shaft or down the firewall in the engine bay.
I've got a clutch on the way anyway, but wondering if this is a fatigued pressure plate, failing clutch master, as simply as needing a bleed, or something else.
Edited by ActionDan
Something physical may have changed with the clutch or the hydraulics....but seeing as you have plenty of adjustment available in the pedal there, just adjust out the excess freeplay that you have, then monitor it to see if it keeps changing. If you get the freeplay coming back, then you really start to work on what is actually causing it. If it stays the same and keeps working, you forget about it after 3 months.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
