Rules:
  • No bouncing - Each rep is to come to a stop on the floor
  • No free falling - Each rep must be lowered to the floor in a controlled fashion - ie no lifting, then slamming it down
  • Belt use is ok
  • No straps
  • No gloves
  • Must be filmed - side on so we don't have to stare at your arse
  • Weight = 100kg - Yes that includes the bar you weirdos
  • Use at least 1 standard sized 20kg plate per side so the height from the ground is roughly the same for all
  • All reps are to be completed in one set
  • No swapping grip - if you start with a double overhand grip, that's your own silly mistake
  • No long rests between reps - Understand that in the upper range of reps you might take 3 breaths down the bottom before attempting another rep, that's fine, make them quick and do the next rep - no taking a smoko while your down there.
  • No Hitching - where you lift the weight to just above the knee, then kind of lean on your thighs and jerk it up instead of a smooth constant lift
  • No bar dip - where you are so tired and you get to a point where the bar stops moving upwards and kind of goes down a little before super powers allow you to pull harder
  • You can deadlift using conventional, sumo, stiff legged or whatever you want.
Winner gets to choose next event.
You can have multiple attempts
You have till End of January to upload your best effort.
Anything I've missed?
Perhaps to cover the 2 ladies we have who might want to play we can make it 60kg for the girls? ie the lightest we can make it to have the bar start at the right height.
Edited by TTT
https://www.sau.com.au/forums/topic/417941-deadlift-challenge/
  • Replies 297
Might try it, without video, LOL. (null & void I know, but hey, I dont do "selfies")
Will have to go SL-style while wearing full lockable knee braces. Good motivation to pickup - no pun intended - deadlifts again.
edit: ^ females @ 60kg. males @ 100kg. Maximum amount of reps. fact is the lighter guys should have it easier with future challenges, such as dips.
100 kg including bar?
Are you f**king serious?
Great idea but I really think it should be done at a % of bodyweight. The bigger and heavier guys clearly have an advantage and this clearly excludes most females (unless they train at PTC!).
There are 2 females here.
and I also stated that if they want to to it they can use 60kg
If you want to make the next challenge a % of body weight, that is fine.
All you have to do is win this one.
K go!
Sounds good mate.
now you just have to win this one to make it so.. :D
Dick. haha. I'll give it a shot tonight, but given how I feel right now I'm not sure it'll go too well :P deadlifts are first up though, so who knows. Unfortunately I know I can't WIN this round given I couldn't match Joey's effort, however bodyweight considered I'll do pretty damn well.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
