I upped a guys PB by 20kg in 5 minutes by raising his hips up
He'd been deadlifting 190kg for nearly a year, 5 minutes later it was 210kg
He was trying to squat the weight up
Check out Martins vid, he pulls 281kg@79kg
Deadlifts are a back exercise
you are right. I thought he was talking about too high vs normal. My vids are on the bit too high side to work my back more , I remember going a lower when going for heavy lifts but, still not squat level. At least that's what I remember doing been a long time. I'm not ready to go real heavy again yet.
Edited by rev210
  • Replies 297
Trozzle - 14
Rev210 - 20
GTR_JOEY - 19
JEPPE - 20 but no vid
R32 Gojirra - 15 but no vid
Birds - 10 but no vid
Added myself to the list until I get a vid up. Will try for one tomorrow.
I do have a vid on my phone but im computer illiterate (im old and shit lol) and dont know how to upload off my phone. Cant do it from work (restrictions) and dont have the net at home (lame i know lol).
Didn't someone do 25?
Added grumbles now, was looking forward to actually pushing it with the squats, 20 still had heaps of room left for more. Got a full 10 out the other day at 72.5 with room so wanted to increase that too. Guess I'll be doing this contest who-knows-when the shoulder is better.
I was... but I'm in the middle of a program for GPC states and TTT scared me by telling me not to hurt myself... I should've done it today when I trained...
I won't win anyway, I HATE deadlifts for reps... anything over 5 sucks balls lol
He just scared you so that so he can beat you and make sure he controls the next challenge....
I don't think it's the reps over 5 you 'hate' , so much as the rest in between sets that your oldman-itis 'likes'. After all , add those 5 rep sets up and you may as well just keep going for 15-20 in a row? ha ha.... just do it and compete . It's more win!
Bit of a noob question...is it normal to have pain after deadlifts? I usually only get it after doing sets of high weight or 1RMing, so it's related to heavy exertion...and it disappears after about 15-20 minutes. I can't tell if it's muscles aching or joints, so am a tad concerned. Have always had it, since doing deadlifts. I ask my friend if he feels the same after deadlifts and he refers to a tightness in his back muscles...but I'm not sure if we're talking the same thing, cause this makes leaning over the basin to wash hands at the end of a session quite painful.
I have had back issues in the past due to bad posture at work, so get cautious when it comes to back pains. And no other exercise gives me that feeling in the area being worked.
I started a DL challenge over on my forum, 2.5 x bw for men and double bodyweight for women
Nina went first and managed 120kg x 10@58kg
I'll get a few of the guys to do some next week, mind you, Zoran, Spiros, Rocky, Mick and Max cant get close, only Martin would beat her 10 at 2.5 x bw (men)
Is it Normal? No.
Is it normal for me? Yes..
lol
Don't be too worried mate.
I'd say you probably didn't hold as tight for one rep or perhaps hyperextended a little at the top on a couple of reps.
When you get a chance, lay on your back and bring your knees up until your whole back (including lower back) is flat on the floor.
lay like that for 5 minutes so it all settles.
nights sleep and you'll be fine.
This is also the reason I don't like lots of reps.
you get tired and sloppy.
I've got one more week of 12 reps and then down to 7 weeks of 5 reps, then 2 weeks of 3s, then 1 week of doubles, then it's time to Beat Nick!
lol
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
