  • Replies 297
Well done to the winner, great job.
Have you ever competed big fella, I know you used to train at MusclePit.
WA states coming up soon
No never competed . I did some lifting/training when I was 30 , with some silly idea of getting ready to do some track and field.. Never did get round to it(track). I was only going to a regular gym that happened to have a decent lifting setup. Was training by myself at the time so learned what I could. I got pretty strong, didn't realise it at the time. I was about 80 something kilos , I can't actually remember the deadlift weights but, I was squating sets of 250kg (235 on the bar) for 5-6 rep sets. I have some pics from back then , with some heavy equipment based lifts.
Had not done any deads since then. This last deads session is only my second since then. Did some training with some friends a few years back but, no deads or squats in that program (shock horror). Got sick a few times in the in between years and lost losts of weight. Plenty of it from the legs.
To correct the confusion I worked with Henry at Xerox (we talked about the comps and training alot) but, haven't trained with him yet.Kept putting it off. Sent a few people his way and figured more recently I would make an appearence once I am ready. I believe I have lots to learn since I have never been coached on lifing properly in my view.
definately like to see if I would be any good at the comp side of things looks like fun.
Edited by rev210
see told you, set the bar high... nice lifting
seriously though WTF crappy bar/plates are you using!? basically doing deads from a deficit every rep due to the small diameter of the plates lol... you could've propped them up on something
Ha ha... yes gheto weights. It's not so bad if I have to travel a bit further in the ROM I suppose, it's all about giving my back a good workout.
I think I irritate the missus as I am pinching all the weights to stick on the bar and then forgeting to put them all back. I think she is keen for me to go to the gym ha ha..
Edited by rev210
Well I reckon you can now set the next challenge mate.
Start a new thread with the next forum challenge.
Your choice.
Look at the results from this thread and make it suitable for the masses... after all it is to get everyone in to the spirit of friendly competition and to push themselves.
Also, PTC Perth hold Novice comps that you could go and try your hand at to get the bite which you will no doubt get to start PL again.
Your choice.
It's still possible for someone to do 28+ today. Come on people , you can't let the almost 40 dude win.
Yeah the PTC is in Malaga which is much closer than Muscle Pit. I am thinking that might be a good place to go.
I really want to learn the techniques to lift right and address the strength imbalances I have. Its more important for me to get that right before training hardcore for strength or comps. I believe that the efficiency of lifting right is actually a great way to safeguard the body for the long term and thats what I am after.
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
