  • Replies 297
Nick got 19 with 130kg today, I'll post vid up tonight
He deadlifted 200kg x 3, then 210kg x 1 and 220kg x 1 beforehand
His hips gave out on the 20th rep, couldnt lock it out
Edited by markos
I think if Nick did it BEFORE deadlifting 220kg lol he MAY have had another couple in him
Nick did his session first and then did the challenge
Its why I find it funny when guys want to rest for a few days before trying, Nick rested a few minutes lol
hehe i felt strong when i did 130kg for 5 reps....
would insert a sexist remark here but cant due to video of the 58kg women being stronger then me....
where do i deposit my man card as i wont be needing it for awhile?
u mean to tell me steak doesnt taste like fruit??
one thing that I dislike about American supplement brands (could be others as well), but they dont have to back up their nutritional claims with any science.
so they can say 350% more blah blah then real steak, but dont have to show any real supporting evidence.
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
