Hi,
I noticed a troubling sound on my 03 M35 (not ARX), when I am slowing down to a complete stop once and I get down to about about 20kph I get a random intermittent 'knocking' sound that sounds like its coming from the rear passenger wheel. Any thoughts? I have also noticed that occasionally the 4WD warning light (well I assume it's a warning light?) comes on which may be related. I haven't got means to read the engine codes at this stage so any help would be greatly appreciated!
Thanks!
Location?
I think you should get it checked asap, sounds like the brake calliper is loose. You will need to get a Consult 3 reader on it to check out the attessa code. I have one here if you are local.
Location?
Thanks for the advice, also got some bearing and tyre issues so I will definitely get it sussed out this weekend if I can! And thanks to everyone elses advice haha, most of it was helpful :P
