  • Replies 62
check the feedback section.. i bet you it involves a large sum of money (in the millions) and some scammer wants you to go claim owner ship of this large sum of money, BUT first you must give me $5000 just to show you are genuine :)
ok, ok sorry i got stuck in a busy burst. here's the letter.
you hit it on the head dave!!
DEAR,
I AM MR.KOFFI AHMED THE SON OF THE LATE SIERRA-LEONIAN BUSINESSMAN,
LATE ALH.AHMED MUTENDE THE OWNER OF (UMS) MINING COMPANY IN
SIERRA-LEONE, WHO DIED 7 MONTHS AGO WHEN THE REVOLUTIONARY UNITED FRONT REBELS
(R.U.F)ATTACKED OUR RESIDENCE IN MAKENI COUNTY OF SIERRA-LEONE.
FOLLOWING THE CURRENT CEASE FIRE AGREEMENT WHICH WAS REACHED WITH THE
HELP OF UNITED NATION PEACE KEEPING TROOPS,I USED THE OPPOTURNITY TO
LEAVE THE COUNTRY WITH A VERY IMPORTANT DOCUMENT OF (USD$21.3M)TWENTY ONE
MILLION THREE HUNDRED THOUSAND U.S DOLLARS.
THIS DOCUMENT IS A CERTIFICATE ISSUED TO MY LATE FATHER BY A SECURITY COMPANY
IN LOME, THE CAPITAL CITY OF TOGO, IN MY NAME FOR THE DEPOSIT OF A BOX
CONTAINING THE ABOVE FUND.
BEFORE MY FATHER DIED HE INFORMED ME OF IT AND ASLO TOLD ME TO BE CAREFUL
BECAUSE THE SECURITY COMPANY OFFICIALS ARE NOT AWARE THAT THE BOX IS CONTAING
MONEY.
ALTHOUGH THIS MONEY WAS REALISED FROM THE SALES OF GOLD AND DIAMOND BUT IT IS
NOT IN DISPUT.
NOW THAT I AM SEEKING ASYLUM IN LOME-TOGO AS A REFUGEE MY MAIN REASON
OF CONTACTING YOU IS BECAUSE I RECEIVED A CALL FROM THE SECURITY COMPANY
WARNING THAT I SHOULD MAKE HASTE TO DISLODGE THE BOX OR I LOOSE IT TO
HIGH DUMURRAGE RATE WHICH HAS PILLED UP SINCE 7 MONTHS UP TILL DATE.
THEY ADVISED THAT I SHOULD PRESENT THE CRTIFICATE AS THE NEXT OF KIN HENCE THE
BOX IS DEPOSITED TO MY FAVOR, BUT CONSIDERING MY STATUS HERE AS A REFUGEE I
NEED YOUR ASSISTANCE.
I WANT TO PRESENTYOU TO THE SECURITY COMPANY AS THE BENEFICIARY, A FRIEND TO MY
LATE FATHER.
THEN AFTER RETRIEVING THE BOX FROM THE SECURITY COMPANY YOU WILL
ASSIST ME MOVE THE MONEY TO YOUR COUNTRY.
I ONLY WANT THIS DONE THIS WAY BECAUSE YOUR COUNTRY IS POLITICALLY
SUITABLE FOR ANY PROFITABLE INVESTMENT, WHICH WILL EMPHASIZE THE UNIQUINES OF
THE MONEY.
HOWEVER I CONTACTED YOU BASED ON YOUR CAPABILITY AND VAST KNOWLEDGE ON
INTERNATIONAL COMMERCIAL INVESTMENT.
MY AIM OF CONTACTING YOU IS PRECISELY FOR YOU TO ASSIST ME IN THE
FOLLOWING WAYS:-
(1) TO HELP ME STAND AS THE BENEFICIARY.
(2) TO HELP ME TRANSFER THE MONEY TO YOUR COUNTRY.
(2) TO HELP ME GET A PROFITABLE BUSINESS TO INVEST THE
FUND BASED ON YOUR PROFESSIONAL ADVISE.
FOR YOUR ASSISTANCE AND CO-OPERATION I AM WILLING TO GIVE YOU 25 %OF
THE TOTAL SUM REALISED AFTER THE SUCESSFULL UPLIFT OF THIS FUND TO YOUR
COUNTRY.
PLEASE KINDLY COMMUNICATE YOUR ACCEPTANCE OF THIS MAIL SO THAT WE CAN
DISCUSS THE MODALITIES OF SEEING THIS TRANSACTION THROUGH.
I COUNT ON YOU GREATLY FOR YOUR ASSISTANCE.
AWAITING TO HEAR FROM YOU SOON.
SINCERELY,
MR.KOFFI AHMED
CONTACTS THROUGH THIS MAIL;- [email protected]
BULLSHIT
i get emails like that all the time!
blady scammers!
Surely you aren't saying that there is something dodgy about this offer?
You said that all you Africans are trustworthy and honest iirc :)
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
