Hey gang, after purchasing the car on Xmas eve, I didn't check the sound system only until recently and found that one of the speakers seemed to be cracked, I was just wondering if anyone could provide me the speak diameters of both front and back as I want to replace them all ableit the tweeters. Many thanks.
https://www.sau.com.au/forums/topic/417957-speaker-diameters/
I just did an install in my Series 2 C34... Standard 6.5" all around.
Used these speakers - http://www.german-maestro.de/US/cs6508.htm
I put splits in the front - tweeters went into the factory A pillar positions and it was quite easy and totally hidden. Just make sure the tweeters are as close to the factory position as possible. While they are a bit thicker than the standard ones, the clips on the grill just clear the tweeter and it all fits up quite nicely. I connected them to the 0db point on the crossover and it sounds pretty balanced and linear.
I used a bench grinder to modify the bracket for clearance and some hot glue to glue the new tweeter into the bracket, then it all just clipped in as factory. I also had to make a 19mm MDF spacer to bolt the new driver into the door.
