When I turn my car off in 37c+ weather the fuel pump makes this weird as hell vibrating whine, totally different noise to when it is priming or running though. I've even got a mate to be sitting with a multi meter ready and the pump is getting 0v but it still makes this weird as hell whining/buzzing/ringing noise for maybe 15 seconds after the car is switched off.
Only happens if the car has been sitting in the sun and I've been driving around town getting everything stinking bloody hot, could it be fuel boiling or something odd? Anyone experienced things like this before? The pump was replaced before I got the car but I believe it is a nismo drop in for an R32, it is however still using the stock wiring loom and getting ~11v.
Ideas?
It's not working then.
The carbon canister is only a part of the evacuation circuit that sucks all the fumes from the tank and into the manifold. There should always be vacuum in the tank, (which is sometimes mistaken for pressure) or the system isn't working as designed.
My old Zoob RX Turbo used to pressurise its fuel tank in hot weather and if it was real hot (hight 30s/40 like today) I didn't tighten the cap . Its hardly going to fall out and I'd nip it up if I stopped anywhere .
I think you can get weird things happening because the pump is trying to return fuel to the tank which is at higher than normal pressure .
I think some of these problems occur because the fuel pump is circulating a lot more fuel than is necessary for the power being used and its possible that at low speeds the steel fuel lines may be absorbing some radiant heat from baking hot roads .
I think manufacturers have sometimes integrated a heat exchanger into the air con system because of fuel temp problems in hot hot weather , may have been an early V12 Jag can't remember .
A .
Ideas?
I know the exact noise you mean, my motorbike has always made the same noise when its hot, from new. Sometimes even 24 hours + after driving it.
Now that you mention it, that might be the case. Will investigate.
On a similar topic why does my car stall after first start particularly when cold?
Idle air valve sticky. Takes a moment to open up far enough to stabilise idle. Moment is too long. Clean up the valve so it moves faster and maybe it will react fast enough to catch the idle.
Ok, Thanks ;)
Some strange replies here so I'll add mine.
While the car is running, fuel is circulating in the rail at pressure controlled by the fuel reg.
Turn the engine off and the rail stays at pressure, maintained by the fuel reg at one end and the fuel pump at the other.
All good.
Now heat soak the fuel rail and that petrol will quickly expand, it has nowhere to go but to open the fuel reg and discharge to the tank.
The noise you're hearing is the pressurised fuel slowly bleeding through the reg back to the tank until rail pressure has stabilised.
Nobody else experienced vapour lock back in the old carby days?
But no Carbon cannister is worth +1000 street creds. :D
but seriously my carbon canister has carbon falling out of it when i turn it upside down...is that normal?
I'm quit happy to reinstall it if I know it works..I love having more junk in the engine bay to make life hard when I am working there..
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
    • Wonder what the cause is, but here's hoping it's nothing too serious.
