I have two turbos, one I was told was a rebuilt and highflowed RB25 turbo, but when I went to fit it the oil drain bolt-holes didn't line up. I have since found out that this could be the pattern of an RB20. Shaft play is almost nothing, but I think I can feel *something*... but apparently that's fairly normal for a ball-bearing setup. It has a braided line on it. It also had a HKS actuator, which I removed to use with my highflow.
The other turbo I bought as a dead turbo for an R33 RB25 with the intention of highflowing it after the first highflow turbo I bought turned out not to fit my car. No cracks and no bent fins, shaft play is minimal, but there is a coating of oil on the blades, so possibly there is a fault there.
I am selling both as dead turbos to have rebuilt (which should be cheaper than having your car off the road while you do some kind of exchange thing). Whether or not they work, I don't know and I don't want to promise but both should be great for highflowing, especially the one that might not need much doing to it!
There is one wastegate actuator, which I *think* came off the R33 turbo. All three items for sale as one lot, pick up only because they're heavy and oily.
Pickup from Forestville, NSW, 2087.
T1:
post-3573-0-71861100-1358401315_thumb.jpgpost-3573-0-16936100-1358401317_thumb.jpgpost-3573-0-70270000-1358401318_thumb.jpgpost-3573-0-31644200-1358401320_thumb.jpgpost-3573-0-75164900-1358401321_thumb.jpgpost-3573-0-25749200-1358401323_thumb.jpg
T2:
post-3573-0-76521000-1358401348_thumb.jpgpost-3573-0-26821600-1358401350_thumb.jpgpost-3573-0-83071400-1358401395_thumb.jpgpost-3573-0-27158900-1358401397_thumb.jpgpost-3573-0-69598600-1358401398_thumb.jpg
The 45V1 is the same as our VG30 BB turbo, except judging by the exhaust wheel, it has been hi flowed as you say, we had to rotate the housing to make it bolt up to the RB25DET,
So much more linear than the stock OP6 .
Thanks for the info!
It looks like the GCG highflow I put on my car in the end, except the oil drain bolt spacing didn't line up with my stock piping.
Replied to Dee
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
