Hey guys, start with the basics;
- RB20DET
- Kando TD05-18G
- Aftermarket Pump (unsure of brand, already in car)
- Nismo 555cc Injectors (to suit RB26 with resistor pack)
- Nistune
Let me begin with, when I initially got the car tune with Toshi, at idle on the wide band car registered 10-11 AFR's. Light throttle would see lean 15-17 AFR's but under full throttle and boost would stay at 10.8-11.3. This was with the TD06-20G I had. Mid throttle sees 13.9-15.5...
So since replacing the TD06 with a TD05 Toshi tried to set the AFR at idle to as close to stoic as possible.
With as much adjusting on the nistune, second time around, car shows 11.9-12.6 on Idle, but now has a tendency to stall after approx 10-20 seconds of idling. It can happen 8 out of 10 idle's, or not happen at all. Still has the light throttle leaness and AFR's on full boost remain the same. I run a AEM wideband also.. When it goes to stall, sometimes if I blip the throttle it'll idle, other times it will want to stall again..
Now I've tested the car with these (individually) disconnected to little to no change;
- disconnect TPS
- disconnect AAC
- disconnect O2 sensor
Car runs no BOV, with a plate made up to block where the factory one lives. And has never run a BOV since owning the car. Car retains the factory AFM.
Injectors were bought second hand. Toshi has suggested putting the stock BOV back on, I'm comtemplating doing this and maybe a AAC clean.
Open to ideas/suggestions/theories...
Kane
https://www.sau.com.au/forums/topic/417992-rb20-idle-expertise-required/
So basically trying to diagnose the stalling and lean conditions. According to Toshi, its set up for closed loop on Idle and under 0psi, open loop once in boost, so dont understand how its lean with the fuel map how it is :(
I don't understand. You claim idle AFR is about 12 in one sentence (rich) and claim that it is lean elsewhere.
Idle: 10-11 (too rich)
Light Throttle: 15-17 (too lean)
Full Throttle: 10.8-11.3 (very safe haha)
Sometimes on idle the AEM shows 17+ AFR and engine wants to stall. It doesnt seem to maintain stoich levels on idle or cruise... So I'm wondering if one (or more) injectors could be the issue? Or something else?
Edited by Kane_R32
  • 3 weeks later...
Just some feedback;
I removed and thoroughly cleaned and reset the IAC to no avail.
I have noticed that when pulling the throttle with the IAC connected the car goes "lean" and splutters..
If during the light throttle I disconnect the IAC, car comes good and doesnt splutter.
Does this sound like my IAC will need to be replaced since I've already cleaned it and tried to reset? Though the slight lean spot on light throttle when being driven is present on the wideband..?
  • 1 month later...
*sigh*
Heres the scenario at the moment.
Car while driving, any gear, any RPM and any speed, from say 2%-25% throttle will show lean on my wideband 16.0+ AFR.. Then when you push the throttle past say 1/4 throttle, it will go into 13-15.0 AFR and obviously rich conditions when WOT.
Also when coming to a stop (idle), the car will idle fine for 20-30 seconds, and then the wideband shows it going anywhere from (11.2-15.7 and then to 16.0+ AFR again, this time causing the car to stall. Bliping the throttle stops brings the revs back up, but again 20-30 seconds after, same scenario.
Car has been checked over and over for vacuum leaks. O2/IAC/TPS have also been disconnected individually to no change.
I'm wondering if my Nismo 555cc injectors have a issue? Car shows 40psi fuel pressure +/- 1-2psi on idle. (and doesnt drop off during the lean condition at idle).
Stock BOV/Stock AFM.
Ps - Can feel this lean spot while driving 2-25% throttle.
Car with TD06 + stock injectors + stock ecu idled fine. (no wideband to tell)
Car with TD06 + Nismos + Nistune idled fine (tune/untuned - no wideband)
Car with TD05 + Nismos + Nistune doesnt like to idle (tuned / with wideband)
With the info above, you would think it's possible Nistune/Tune related right?
It should not be able to go lean at <25% throttle light load because it should be in closed loop and should command 14.7:1. The only way it could do it is if the O2 feedback has been switched off and the maps set that lean in that area. In which case it would be like that all the time, not just start out of the blue.
It is possible that something as simple as a coolant temperature sensor might have failed. That's one of the inputs that determines when and where closed loop is allowed. Do you have Nistune software? If you do, you should drive around with it hooked up and see what you see. It might jump out at you.
You might be onto something.
Because I was originally seeing sub 11.0 AFR on idle with the TD06, he turned off O2 feedback and tried to adust/lean it out, with no result.
I think the cleaning of my AAC and any leaks has solved my rich idke issue, and I may need to have the feedback turned back on...
Hmmm. No Nistune software..
Appreciate the help man! :)
  • 3 weeks later...
Went and saw Toshi, 02 feedback wasnt switched off. We did find a couple air leaks which have now been sorted, yet it still does the same thing.
Starting to wonder if my Nismo 555cc injectors have an issue.
He did mention the AFM voltage is a little low at idle... but shouldnt cause too much concern
  • 2 years later...
I have similar problems with nistune, I figured it was the factory O2 causing the problems. Can be from 12-16afr's on idle while sometimes perfect at 14.7. Can be lean entering boost 13's but drops to 11.3 afr's at 15lbs and holds afr's there.
Makes sense that it would be O2 or IAC.
if you've swap the AFM with the Nistune, and done all that rescale business make sure you change the values to the AFM Low Voltage enrichment, a few cars I've tuned needed this changed as once the car idles the ecu starts dumping in fuel and then the o2 feedback tries to correct it causing awesome hunting
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
