1. Turbosmart Dual Port BOV kit with extra trumpets to make them completely atmospheric or have them plum back or half half or full recirculating. fitted once and removed basically brand new $250
2. Nismo Super Copper mix twin plate clutch near new 95%friction material still on it, suited for pull type BNR33, was used for about 4000 km's street use only was fitted to my 260RS $1800
3.Still way 0-400 shifter, drag racing shifter enables you to shift up gears and not mis shifting in to wrong gear. $240
4. Apexi Super Suction set with 2 z32 AMFs. $250
5. Greedy Profec B Spec2. $150
6. R34 GTR Rear Seats $200
7. R34 GTR S2 Rear Sears $350
8. R32 GTR Front Guards. they got bead blasted when my R32 was being put through restoration the guy who blasted it said oh I'm not meant to blast alloy, there are slight dents on them but can be fixed quite easily $150 for the pair
9. WGNC34 S1 Factory Front Grill with Autech sticker on it. $100
10. WGNC34 S1 260RS fiber glass front bar with vents moulded in to the bar. lower lip has slight damage to it $300
11.WGNC34 Greedy adjustable coil overs suited for 260RS not sure what the spring rates are, very firm ride no knocking or leaks.$250
12. WGNC34 S1 Manual center consol and ash tray vents and control surround $300
13. WGNC34 S2 Auto Center consol $50
14. WGNC34 260RS standard radiator. $50
15. R34 GTR Vspec front bar with diffuser just had respray in Bayside blue, lower lip needs another paint. $500
16. R34 GTR Vspec complete front end just had respray in white, this came on the 34 i bought but z tune kit is half here and half in japan so need to make way for it. i would like to sell this one as a complete set, Front bar with lower lip in black and lower diffuser and grills no badges, guards and bonnet. $1200 if to be broken up it will be bar with lip and diffuser $500 guards $350 Bonnet $600
17. R32 GTR Rear bar, has broken tabs on one side $50
18. R32 GTR Carbon exhaust rear bar shield $100
19. R32 GTR Carbon N1 vents $120
20. WGNC34 s1 260RS Front seats VGC $400 for the pair
21. TE37 custom powder coat, they were black when i got them since then i have had them blasted and recoated but am planing on blasting them again and getting them painted in white which is what is on the stickers say. also come with fedrals 595 with about 10000 km left on them $2350
22. R32 GTR intercooler $150
23. R34 GTR Nismo S-Tune Shocks off my 34 pretty sure it will fit on 33 GTRs as well not sure what kinda of condition they are in as i have not driven the 34 yet and i have Tien RS's being built for my car. $600
24. Nismo LMGT4 bronze 18 9.5+12 $2400
There are still a whole heap of items i need to list and take photos of but ill probably have to start a part 2 of items i have for sale, anyways just pm me and ill get back to you asap.thanks
http://s1320.beta.ph...onle88/library/
  • Replies 50
nha they wont fit they will only fit 260rs because they have the GTR forks on them or they till fit an r33 GTR if you change the tophats to suit a R33 GTR will have pics loaded up on photobucket tomorrow
Hi - could you please send me a pic of # 18. R32 GTR Carbon exhaust rear bar shield $100.
reply to PM or email [email protected] thanks
Keen as mustard.
Cheers
Richard
Hi would you have a clutch fan blades for sale and a radiator overflow bottle ? Pete 0415160343
No just items that are listed
18. R32 GTR Carbon exhaust rear bar shield $100.SOLD pending payment
Plse re-email account details. My payment was returned (acct does not exist)
Likely I got a number wrong
Thanks
11.WGNC34 Greedy adjustable coil overs suited for 260RS not sure what the spring rates are, very firm ride no knocking or leaks.$250 SOLD
    • have you rotated the car yet? if so how smooth was it?
    • And finally, I had the driver's side airbox off while adding a long drain hose under the oil can to down near the oil filter. Doesn't look good, it has definitely had an turbo oil seal leak and looks like it has been for a long time.....guess I'll have to get a pair of highflows to put on the shelf It's also worth mentioning it has a really strange clamp between the bottom of the airflow meter (which has a big barb/lip on it) and the intake pipe. I've used the magic of MSPaint to show, basically you have to clip out those 2 steel springs which unlocks the hose from the AFM. I used 2 flat screwdrivers, the spring sort of clips into the unlocked position. Reassembly you just pop them both back flat once the hose is far enough up the AFM that the spring clamp is above the barb. Weird to use but much more convenient once your'e used to it compared to trying to do up a hose clamp under the airbox like on 32 GTR
    • The other thing I started was a fire extinguisher bracket.  As with a few other cars previously (350z, Leaf), I'm going to add a bracket between the navigator seat's front bolts, then mount the extinguisher on that. Unfortunately Nissan (probably the same engineer who did the A/T fluid interwarmer) decided that the front seat brackets would be recessed and uneven so the bracket shape was a bit tricky; I ended up doing 1 part under each seat mount (the large hole is because there is a flange under the seat mount to allow for the carpet thickness)   and then a horizontal part between those 2 No final pic yet as the paint needs to dry, I'll post up once that's done
    • OK, a few half jobs on the skyline this weekend because its booked for a test day at Wakefield Park on 27-Feb. While the Ecutek dongle and app provide display and logging of a heap of engine parameters, they annoyingly don't have access to the auto trans temp. So I grabbed an oil temp gauge from Raceworks which apparently has warning colour change and peak hold, about $95  and their 8mm hose sender adapter Now, I foolishly thought these 2 might work together, but no, the sender needs about 30mm clearance in the fitting and the adapter only had about 8mm. I've cobbled something together with an NPT T piece and blank for now but will try and work out something more permanent as I intend to use the same fitting for the data logger in the future. Under the car, Nissan's engineers decided that only one opportunity for coolant and trans fluid to mix (the radiator) was not enough, and they also added an interwarmer near the sump on the passenger side like the engine oil has: I've cut the hose between the auto trans outlet and the interwarmer inlet and inserted the sender there as that gives the best indication of temp inside the transmission.   From there it is back to the pain of running that sender wire to the cabin, I've run it up near the passenger headlight, into the battery box, across the channel at the back and into the master cylinder area where I ran out of wire length (and patience). Remainder of the job is through the grommet near the accelerator pedal that I've used previously, then across under the dash to where I will temporarily mount it on the console for track days (and remove it other times). The gauge will also need IGN, BAT and earth (I'm not going to worry about illumination as I'll unhook it between track days)
    • This piece is obscenely discontinued. I honestly hate the frameless window design because the rubber gets stressed and the guides as well every time you open and close the door.
