Hi mate, had this before - you will need to take the headlight to a place that can;
1. place it in an oven to soften the glue that binds the headlight
2. pry open the headlight and re-clip the blinker cap
3. re-seal the headlight with new glue
if you're unable to dis-mount the headlight yourself and are in sydney, you can take the car to Top Secret in Blacktown - who can remove the headlight without damaging any of the clips and then organise for the headlight to be repaired at Plastifusion - which is just around the corner - whilst your car is kept safe at the Top Secret workshop;
if you can remove the headlight yourself you can take it directly to Plastifusion for repair
Top Secret Service Center;
Jack (director) or Pete (head mechanic)
Unit 2, 1-3 Carnegie Place, Blacktown
Phone: (02) 9621 5700
[email protected]
http://www.topsecret....au/index-1.php
Plastifusion
Address: Unit 2 170 Sunnyholt Rd, Blacktown, NSW, 2148
Phone number: 0298318018
Read more: http://www.startlocal.com.au/auto/wreckers/nsw_sydney/Plastifusion_2487986.html#ixzz2IEHAyCe2
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
