Hi
I have just brought an R32 gts-t with RB20det
After a while it developed a misfire, i pulled the plugs and noticed #6 was totally black while the others where white/grey like they should be
So i did the following things
- Test coil packs and swap them around
- Replace coil pack loom
- Compression test 158-163 across all cylinder s
- replace spark plugs
....but it continued to foul #6 after a while, people would look at the fouled plug and tell me its fouled by fuel
so then i
- had injector cleaned and flow tested (thinking injector #6 was dribbling, it tested fine)
- leak down test on #6 cylinder which got 85%
....but it still fouls continually #6, runs better with nice clean injectors but still fouls #6 and develops a misfire ?
when i come back from a drive remove #6 plug to check it i look down the spark plug hole and the piston looks very wet
Anyone have any ideas ???
Maybe an ECU fault ?
Who and when was your last tune done ?
That's where i'd be looking based on the actions you have undertaken so far. (AFR's)
Edit: compression looked okay. Leakdown on remaining cylinders ? other than 6 ?
your compression results are excellent for an rb20det I've checked a dozen or so and most are not above the 140psi range...
the first thing I'd do is check the ecu for fault codes and go from there, quite possibly a faulty igniter module or ecu...
Tried another igniter module and it was still misfiring, although plug was fouled by then
15% leakdown is not good. How does it compare with the others? Try a hotter plug in that cylinder.
Didnt test amy other cylinder with leakdown test, came with BCPR6ES gonna get some 5's tomorrow but all that will do is prolong the fouling
Suggesting missfiring in 6 not burning fuel. Smarts
Dont think there is a misfire before the plug has fouled, the car idles sweet and revs clean all the way to 7000rpm untill #6 fouls
Thanks for ideas everyone
Just put the hotter plug in #6. There's no reaon why it will "prolong the fouling". It will either cure it or it won't.
The BCPR6ES's i had in there foul pretty quickly, tried a BCPR7ES that i had hanging around and that fouled just driving down the street.As hotter plugs are not as prone to fouling i thought id try some 5 heat range plugs which would not foul as quickly but im sure will eventualy foul. Pretty sure it is not the heat range of the plugs which is causing the fouling
what condition is the coil pack harness in? changing the plug isn't going to solve the problem , put a multimetre on the plug for the coil pack with the car running and test the voltage getting to the coil pack
The coil pack harness was replaced with a good cond s/h one, have tested the continuity of the ignitor but yeah ill test voltages running to the coils
Had another thought, the engine may have blown a headgasket then been chemiwelded, the chemiweld has sealed the water passages up so no oil or exhaust charge is getting into them but oil is getting into cylinder #6 which is causing the fouling.
But i thought the leakdown test would have shown this???
Your leakdown test was what I understand to be in the unacceptable range (15% leak) so yes there is an underlying problem. Who did the leakdown test and did they offer any analysis? My engine runs fine without fouling plugs - my compressions are way below yours but a leakdown test resulted in 5% to 8% range - not flash but I have no discernable problems.
I am not suggesting that incorrect heat range for the plugs is your problem - I'm just suggesting you try a hotter plug (or full set if you're so inclined) to see if it will fix your symptoms short of pulling the engine and stripping it down.
I did the leakdown test and my analysis in i think my engine i trucked
Yeah replaced all spark plugs with 5 heat range as overtightened thermostat housing and broke it so cant drive car till i get a new one :-(
Thanks for your help
I'd get the injectors flow tested. The injector might be a bit leaky and pouring excess fuel in
yeah had that done
marked #6 injector and it was tested first and tested fine, two others ended up being leaky so two s/h replacements and cleaning and flowing cost me $260 to not fix the problem :-(
    • My understanding is that UV tends to accelerate the aging process. If the car has been garaged, then you could probably get away with extending beyond 10 years. FWIW, in 2015, I had tyres on my 180B SSS that had a 3-digit code (2 for week, 1 for decade), ending in 0, so could have been more than 30 years old, but still worked fine. I did replaced them very quickly, though, once I discovered what the code meant!
    • But we haven't even gotten to the point of talking about stateless controllers or any of the good stuff yet!
    • You guys need to take this discussion to another thread if you want to continue it, most of the last 2 pages has nothing to do with OP's questions and situation
    • And this, is just ONE major issue for closed loop control, particularly using PID. One such issue that is created right here, is integrator wind up. But you know GTSBoy, "it's just a simple PID controller"...
    • Nah. For something like boost control I wouldn't start my design with PID. I'd go with something that originates in the fuzzy logic world and use an emergency function or similar concept. PID can and does work, but at its fundamental level it is not suited to quick action. I'd be reasonably sure that the Profecs et al all transitioned to a fuzzy algorithm back in the 90s. Keep in mind also that where and when I have previously talked about using a Profec, I'm usually talking about only doing an open loop system anyway. All this talk of PID and other algorithms only comes into play when you're talking closed loop boost control, and in the context of what the OP needs and wants, we're probably actually in the realm of open loop anyway. Closed loop boost control has always bothered me, because if you sense the process value (ie the boost measurement that you want to control) in the plenum (after the throttle), then boost control to achieve a target is only desirable at WOT. When you are not WOT, you do not want the the boost to be as high as it can be (ie 100% of target). That's why you do not have the throttle at WO. You're attempting to not go as fast as you can. If the process variable is measured upstream of the throttle (ie in an RB26 plenum, or the cold side pipework in others) then yeah, sure, run the boost controller closed loop to hit a target boost there, and then the throttle does what it is supposed to do. Just for utter clarity.... an old Profec B Spec II (or whatever it is called, and I've got one, and I never look at it, so I can't remember!) and similar might have a MAP sensor, and it might show you the actual boost in the plenum (when the MAP sensor is connected to the plenum) but it does not use that value to decide what it is doing to control the boost, except to control the gating effect (where it stops holding the gate closed on the boost ramp). It's not closed loop at all. Once the gate is released, it's just the solenoid flailing away at whatever duty cycle was configured when it was set up. I'm sure that there are many people who do not understand the above points and wonder wtf is going on.
