Guy's for sale I have my JHH built 26/30. Motor was rebuilt in 2008 and has about 15000 k's on it (3x powercruises) as its wasnt my daily driver.
I am on the southside of brissy...
The motor consists of a standard RB30 o ringed block, N1 oil pump with crank collar fitted, Argo rods, wiseco pistons, 2005 JHH street head on it(larger exhaust valves) with Tomei stage 2 cams, Greddy cam gears. Will from JHH has stated that metal headgasket should have no Problems being fitted now.
Car made 580rwhp ATW years ago with my oldschool garrett 42R and last made 550rwhp through my auto on the Horsepower Solutions Dyno last time I had taken it. Engine will come with intake, coils, crank angle sensor etc.
Motor is still in the car and running well. The car has been running awesome and shreds the tyres under boost up to third gear.
Only reason I am selling is to pay off a loan I dont need and the car is worth more to me in pieces.
To see my car in action go to youtube and put in willallan77 and go for JD Transmissions R33 vids
Also for sale is my JD Transmissions 300zx box(rated at 1000hp) complete with 5000rpm converter(awesome streetable converter from the converter shop) and tailshaft (suits R33 GTST). Looking for 5 grand which building the box costs over 5 grand new and you need to source a box and converters as well. This box is the ducks nuts and Joel is an absolute champion bloke.
Box will not be sold before motor...
Happy to sell motor, box, manifold and turbo for 10 grand under a bundle deal.
If it doesnt sell then ill keep it as i'm not desperate.
If interested PM me or call 0422886721.
I dont sell crap or rip people off...
Cheers Bill (Imtorqing)
https://www.sau.com.au/forums/topic/418010-fs-forged-2630-5000/
  • 3 weeks later...
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
