Haha or NOS...2 of the big ones...Nah, once you hit 400kw there is no longer simple answers...could you use less boost of the line maybe through the first 2 gears...then jack it up to finish
If I was going to build a drag car I'd be running an auto anyway, it must be annoying you the illusive 10...
I've tried starting on low boost then going to high midway through third but it didn't really help, I found modulation of the throttle and clutch the best so far, the hardest bit is the launch, trying to find the sweet spot between wheelspin and bogging down.
Every day is different I've found, between launch RPM,air temp, track temp, tyre pressure and size of burnout.
What worked last week generally won't work the next week.
It is frustrating but fun at the same time.
My birds alfa will spin the wheels if you mash the pedals, its all about good throttle control.
I can launch fairly hard and with good throttle and clutch control get the power to the ground with minimal wheel spin, my tyres are 255, power is a tad over 500 hp.
Do some driver training days and/ or track days and learn how to drive a car with a hi power motor.
Putting down the power is a skill that needs to be learnt.
Otherwise old mate in his 100 hp auto lancer will smoke you.
I'm not taking the piss here, I've talked to people who claim their car will spin the wheels in the first three gears, why, because they just drop the clutch and mash the pedal.
With great power comes great responsibility.
The skyline has f**k all compared to my old cars
growing up in snow country and road racing sports cars for a while i do know how to drive it
the car is very sensitive to drive with no weight on bumpy ass roads in oz
Too stiff is a big issue and lack or torque down low on rb25 till it hits some boost at 3500 ish
Softer rear end would be a lot better hook up
I've seen a lot of 25,s at trackdays that go well on street tyres without excessive wheel spin, its all of the mechanical skills plus being able to read the road and drive to the conditions.
Each to their own I suppose.
but the thing is if u want to go fast on a track or accelerate hard, then you gotta mash the pedal, no?? Else you will hardly be faster than a v6 commy. Well initially, anyway..
Did you really just say that?
Wow man...
Throttle control is about using the throttle so that you do NOT wheelspin, whilst using maximum amount of throttle.
Watch V8 Supercars on TV when they have the camera on the pedals. They don't mash it out of the corner - they progressively apply the throttle so that the car does not wheelspin, and is thus - faster.
Wow man...
+1^^^^
Wow man...
Ha ha your right, I have yet to learn n fine tune some driver skills
so throttle control applies to coming out of corners but in a straight line do they not just mash it? If your already in a straightline, then with a good setup it should swat down and pretty much dig in,
Edited by AngryRBGTX
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
