Dammit! How did I miss this! :( Oh well, you guys couldn't find a 5 lane part in the tunnel? Im pretty sure if you enter the airport link from toombul and head towards the city there is a 4 or 5 lane part or a small stretch at least?
  • Replies 110
Posted Images
Awesome to meet you guys last night...
Yeah pity about the rolling shots, daytime would be good but need to pick a day and time we can get this done on the M1 without disturbing the peace.
PM will be coming with email addy..
Did any of the rolling shots work?
Noy
Great to Catch up with you guys last night, the individual photos taken by the very able members/photographers look great. Was thinking of what we need for a action shot, Something like that huge Square piece of bitumen at the Mt Cotton Driver Training Centre..
Tony / Martin, submitted my qld club membership application earlier today..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
