Whenever you do a mod to your car it's handy to have some insuctions if you've not done it before, so I thought I'd make this tech article.
This shows how to install a band expander for your radio if you have an imported V36.
Also i have a question for someone with more knowledge on this than me. After the above install I did get more radio channels but they are not very crisp. Any thoughts?
https://www.sau.com.au/forums/topic/418082-v36-band-expander-install-guide/
Frequency band expander install for imported Japanese radio in a V36.
Allow 45min. for first timers.
1. Tools:
Phillips head screw driver
Small flat screwdriver for undoing cable plugs.
2. Parts: Frequency or
band expander (this one is
from synergy) $50
delivered in a few days
This is the old style and
won’t work on the V36,
more suited to the 300zx
etc. I Found out after I
had already removed the
radio. Wrong connectors
Step 1. park the car somewhere shady, open the windows and doors. Now disconnect the battery negative terminal.
Step 2. Gently push down on the plastic sheath
Step 3. Unclip the shift know clip, carefully as this
can spring off and disappear as it is a kind of
spring clip.
Step 4. Roll down the shift boot,
there is a small looped piece of
wire inside the boot which holds
it on. Notice it will have a pointy
side, it is not round. Later when
you get the shift shroud off
remove this wire and squeeze it
closed a bit. This will tighten it
for re-installation later on. See
the second pic also.
underside later
Step 5. Slide the shift knob
off, try not to touch the
white part as it has grease on
it.
Step 6. Put you’re your
fingers into the boot as
shown and pull back and
slightly up, not hard, two
fingers should be enough.
Lift the shroud up a bit. You
will notice it fowls on the
shift lever.
Reach under the shroud and
pres the white square under
where the shift lock is. Now
you can move the shifter
back to N and lift off the
shroud. See third and fourth
pic also for step 6.
Carefully unclip the two electrical connectors and place the shroud somewhere safe.
Step 7. Now you are left with this.
Next remove these two screws at the bottom outside corners of the radio facia.
Then lift out as shown.
Undo harnesses
Now undo the three wire connectors.
The flat screw driver can help push
Down the clips to allow them to be
removed.
Step 8. Remove the next two
screws under the airon/TV screen facia
Lift out the display surround from
the bottom first.
Now you can see this
Step 9. remove these two screws
under the screen, they held the screen and the radio housing.
And the two screws under the
radio unit.
Step 10. Pull the radio unit
forward, the plug your looking
for is on the right hand side of
the back of the unit. In this
picture you can see it after I have
disconnected it. This one is a bit
tricky as the unit is still held in
with a heap of other wire
connectors, so just be patient with
it, don’t want to break anything
in there.
Now simply connect the band
Expander to this connector, and
The other end to the radio unit.
Tuck the expander module in
behind the radio, I put mine in
the space beside the radio unit
and the relays on the drivers side.
Now just put it all back together
in the reverse order.
Sorry about the poor cut and paste method of displaying the above. I did in word but the file was 74Mb and I have word 2000 so can't compress the files :P
So still trying to find out how to improve the clarity of the stations though.
Well I moved the expander housing to behind the HU instead of next to it and the relays. Thought the relays may have been interfeeing with the reception, no. Didn't fix the problem. But after I had put it back together I though I'd check the expander was connected properly. It was, but what I noticed which I didn't notice when I installed it, is that the stock wire harness connector has three wires and the band expander only has two. So I'm guessing that this wire that is missing from the band expander is some sort of AC power wire. Hence I have the same problem most have where the power to the antenna is not properly connected. More research is needed. Need to install a wire on the band expander to try it out.
Original harness.
It's the large black wire (near my thunmb) that is missing from the band expander.
The band expander harness
Ok so problem solved. I was correct, the missing wire in the band expander is required. I was able to diconnect the existing wire from the existing harness and connect it to the new harness. Then connected the band expander using the OEM plugs and Bobs your uncle, I now have a working radio. I have photos but photo bucket is not works. Also if anyone is thinking of buying from Synergy there is nothing wrong with this product. You can still make it works plug and play. Also might I add their customer service is great.
  • 3 months later...
  • 4 weeks later...
SO I bought another band expander this time with a power wire. Connected the power wire to the violet cable on one of the hard drive harnesses that showed 12v when ACC on. Check with multi meter and there was power to the band expander when acc on. Put it all back together and I have no radio signal at all.
To make thinks worse i pulled it appart to check again but had been fiddleing round with the multimeter in between. Wen I checked again with the multimeter from the body of the radio housing to the power wire there was a tiny spark now I have nothing in the centre consol working. No ac, no dispay on the touch screen and no radio. I've checked all the fuses I can find, drivers foot well and near the battery, all fine.
Please help.
Ive checked every fuse on the car and they are all ok, including the ipdm fuses. Just had another look and there still seems to be some power to the harness on other wires. Perhaps the repair is a simple bypass of the wire I fried?
Chris will try to get the missus to bring the car up during the week.
  • 3 weeks later...
  • 4 weeks later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
