Hello,
Back in November I took my car to the tuner.
I am running a power-FC on a 1998 r34 GT-T RB25DET NEO
550 injectors
GT-RS turbine
poncams
Z32 MAF
The car came back but has had issues running very rich (10.0) when cold to 50 Celcius
Once warmed up around 80C the car runs fine (idle 14.7) except that when you punch the gas it studders then engages.
I took the car back to the tuner and he says that it is having an issue he has never seen before. On the data logger when you push the throttle there is a momentary drop in AFM voltage then it raises as it should.
The MAF is brand new and has been tested as fine in another vehicle. All of the other parts are also brand new. Also the engine was just rebuilt.
I went to pick up the car today from the tuner again because he can't seem to figure out the problem. He left me a note that said that he had noticed something. If the car is not turned on and you depress the peddle the AFM voltage and the throttle voltage rise together and at exactly the same value. It seems there may be a crossed wire somewhere or maybe it is supposed to be like that. He said to check the harness. I was wondering if anyone else has heard of a issue like this before. After the initial pause the engine runs fine. It is just the initial push that has problems. Thanks.
https://www.sau.com.au/forums/topic/418113-r34-maf-voltage-issue/
agree. MAFS-1 should not change when the car is off and you press the accel pedal
cant be too hard to trace the signal wire when it was spliced at the afm plug, this is where its likely to be wrong
before you go looking at all the wiring... have you tried a brand new battery... reason for asking is if it has dropped a cell or 2 then there might not be enough amp's running though...
very simple thing to test and rule out before going to the effort of wire hunting... poor battery can lead to a lot of issues people dont consider...
Yeah, but hard to imagine low battery voltage causing the signal from one sensor to appear on the wiring for another.
agreed.. but think about a bad battery and all the warnings a dash will show... i had a bad battery show the oil light, park brake and light bulb warning... replaced battery and all fixed...
as bad battery can show up random things and is a simple thing to check which requires minimal effort... even just leaving the battery on charge over night and check again in the morning... cost nothing to rule it out :)
I ran new wires from the MAF directly in to the ECU ports for AIR signal and Signal ground. Same result. So it is not the wiring harness. Does anyone else have a Power-FC in a ER34 that can try this out. Turn the car to on but not engine running put the PFC into monitor mode for AFM and watch the voltage whilst pushing the gas pedal. Any help would be appreciated. Thanks for the replies.
Edited by debusan
One other comment I would like to make is that my car is an AT/MT conversion. I am well aware that the AT harness has several pins that are not used by the MT or PFC ECU. But as far as I can tell from the wiring diagrams none of the pins in question are different between the AT and MT harness.
why are you using manual powerfc on auto car? you know its not supported right?
but anyway look at ETC, SENSOR SW CHECK and look at the values of MAFS-1 and TPS
do they both change at the same time?
I do see your point though The AT harness is heaps different and getting a MT harness may un-screw lots of these problems I have attached a shoddy video to show the symptoms on the hand paddle. I appreciate your help
http://www.youtube.com/watch?v=vl7LBBoAFRU&feature=youtu.be
FWIW, the fact that the car has been converted auto to manual shouldn't make any difference. You can run a manual engine with an auto ECU and vice versa. The car won't work well with a manual ecu in auto car because of lack of comms to the TCU, but that doesn't matter. What matters is that all sensors and outputs at the ECU that are involved in running the engine are same same.
It is entirely possible that you have a crossed wire, as we said earlier, or that your PFC has a severe problem. Can you swap in another PFC?
Yesterday I tried hard wiring the MAF into the Power FC I had the same result that was with me running all new wires straight from the PFC to the MAF. I don't have another Power FC and its a 1000$ to get another one in there. But if I must buy one then that is the answer. The traction control unit has been disabled. and the valve removed. so it should not be an issue.
Edited by debusan
So thanks to some info above I have uploaded a video of the PFC switch/test screen that shows the voltage issue in detail. I have a couple more things to check but I am starting to think that the PFC is the culprit as it is the only used part I installed in this car. Guess I need to fork over some cash then.
http://www.youtube.com/watch?v=H31n2YUQjyc&feature=youtu.be
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
